scanner wont connect to ecu after rainy day and key started flashing too
Old Sep 13, 2019 | 01:55 PM
Ozkar Oxoa's Avatar
Unhappy scanner wont connect to ecu after rainy day and key started flashing too
hi, im having a issue getting my scanner to read my ecu, checked every fuse and relay and they look fine, also my key started flashing on my dash, it cranks but no start. took out my ecu to see if is damaged and also found nothing burnt or disscoloration, hope anyone had this kind of issue and was able to repaired
Old Sep 13, 2019 | 05:51 PM
doctor J's Avatar
So did it start before you hooked up the scanner?
If so what was the scanner brand and where did you get it from?
Old Sep 13, 2019 | 11:00 PM
Ozkar Oxoa's Avatar
everything happened after a storm water got somehow inside the fuse box under the hood while driving and my key started fashing green after trying to start, i got an innova 3150 and it didnt connect, tried an elm 327 and nothing neither, checked every fuse under hood and dash, took my ecu apart and everything inside looks new
Old Sep 14, 2019 | 08:49 AM
doctor J's Avatar
Let me look on schematic and "guess" what it could be
Old Sep 14, 2019 | 10:04 AM
Ozkar Oxoa's Avatar
thanks, i appreciate your help!
Old Sep 14, 2019 | 11:48 AM
doctor J's Avatar
Probe tabs on the following fuses with 3.4 watt 12 volt test light
Fuse 8 (underhood box) hot at all times
and fuse 11 (fuel pump, 15A) in under dash box (ignition ON)
Old Sep 14, 2019 | 01:48 PM
Ozkar Oxoa's Avatar
i will check them after work since i got the ecu with me. thanks and i will update you if those 2 fuses aren't hot
as far as can tell, nothing looks burnt or discolored
Old Sep 14, 2019 | 07:55 PM
Ozkar Oxoa's Avatar
checked those 2 and they are working, both throw 12.4 volts each
Old Sep 14, 2019 | 08:03 PM
Ozkar Oxoa's Avatar
Old Sep 15, 2019 | 04:40 AM
doctor J's Avatar
What else , in addition to immobilizer and scanner, does not work? Is check engine light on with ignition ON, (with engine off) ?
Old Sep 15, 2019 | 11:28 AM
Ozkar Oxoa's Avatar
yes, CEL is on and immobilizer light blinking, do you think it might be a bad ground (G101) going to the ecm? i did a jumper with a 15a fuse to check the fuel pump relay and i can hear it prime, but still no start just crank.
Old Sep 15, 2019 | 01:46 PM
Ozkar Oxoa's Avatar
how to tell if an ecu got damage?
as my pics showing above, i don't see being damage or shorted?
can a Honda HDS connect to the immobilizer system even when it is not receiving data from the ecu?
Marimar
Jan 25, 2017 08:36 PM
nielmot
Sep 2, 2016 07:16 PM
lightyear22
May 1, 2015 10:19 AM
NIGHTHAWKSI
Aug 28, 2012 08:01 PM
davidteddiilin
Mar 26, 2012 05:54 PM
