2007 Fit with clicking & clacking from engine. Can anyone identify cause of problem?
Old Dec 8, 2020 | 04:17 PM
jazzjazz's Avatar
Old Dec 9, 2020 | 04:34 PM
Jared592's Avatar
Sounds like an exhaust leak to me, either where the exhaust manifold meets the cylinder head or further back. If you take off the metal shield (it's 3 10mm bolts if I recall correctly), you can get a better look and (very carefully) feel with your hand around the manifold with the car running. You should feel the pressure of the exhaust escaping when you get near where the leak is.
Old Dec 11, 2020 | 09:58 PM
tyrtill's Avatar
That is strange sounding almost like a miss. From my history with fits I would check to make sure spark plugs are tight (doesn’t sound like that problem but maybe) then take the serpentine belt off (only run it a short time like this as the water pump won’t be running) and see if the problem is still there.
A small section of hose on your ear can help give you directional hearing or a screwdriver with a long tip resting on the suspected component.
Old Dec 13, 2020 | 08:16 AM
doctor J's Avatar
Second for loose spark plug as exhaust leak is more consistent and tend to go away at normal temperature. If plugs are OK, take the drive belt off and run engine for 10 seconds to rule out belt driven accessories.
jazzjazz
Dec 15, 2020 08:37 AM
short1
Aug 11, 2013 09:49 PM
guailifit
Puerto Rico Community
Mar 23, 2012 12:33 PM
lrf487
May 26, 2009 06:38 AM
Luichenwai
Aug 29, 2008 09:48 AM
