PCV Valve Replacement
In my 08' Fit, I have oil on my oil cap from air blowing up to the cap. My friend was saying he thinks the PCV valve has gone bad and it needs to be replaced. Do you guys think this is the case or is it possible there is another problem?
Thanks! |
Your friend might be right. But it could also be something else.
If you haven't replaced the PCV valve, you should. |
Originally Posted by hotkey
(Post 1462666)
If you haven't replaced the PCV valve, you should. I appreciate the help! |
