'07 Fit Hum
Old Dec 1, 2022 | 10:58 AM
obfit's Avatar
'07 Fit Hum
Hello all, My daughter's '07 Fit Sport (118K miles) is producing a rhythmic hum from the engine compartment every now and again while she is stopped and the car is idling...goes away when she accelerates to speed. Has only happened a couple of times so far. You can hear it in the video...gotta ignore the turn signal. Any ideas?
thx
File Type: mov
Old Dec 26, 2022 | 11:50 AM
mifesto's Avatar
from the noise, i would suspect blown engine or trans mount. noise sounds metal clattering against metal.
Old Dec 26, 2022 | 11:55 AM
obfit's Avatar
Understand...is there a method to determine which mount may be the culprit? Thanks!
Old Dec 26, 2022 | 12:53 PM
doctor J's Avatar
Assuming the car is automatic:
Noise in drive or reverse only: the rear center mount
Noise in all ranges: jack the engine slightly when it's running; if sound goes away check the passenger side motor mount for crack around the rubber cone
Old Dec 26, 2022 | 01:12 PM
obfit's Avatar
Excellent...many thanks! Happy New Year...
Old Dec 26, 2022 | 02:14 PM
mifesto's Avatar
check for cracks or rubber seperation, also have someone rev the motor, which will load up the mounts and help check for wear
Old Dec 26, 2022 | 02:17 PM
obfit's Avatar
Got ya...thanks!
Old Jan 2, 2023 | 01:24 PM
obfit's Avatar
So I may have located the source...was checking the different motor/transmission mounts and noticed the catalytic converter heat shield was missing a couple of corner bolts that
had rusted out. The two pieces were loose and could rattle together, so I wired em together nice and snug. So far no repeat of the noise...we'll see if that did the trick.
Old Jan 24, 2023 | 06:06 PM
mifesto's Avatar
cat heat shields will rust into nothing in almost any car but if thats not your source of noise then its the manifold heat shield vibrating.
JrARIA07
Oct 19, 2016 05:45 AM
p nut
Feb 21, 2015 12:49 PM
C2AUTOSPL
597
Jan 20, 2015 01:40 AM
KingKable
May 23, 2014 09:30 PM
AkbarGr8
May 6, 2010 01:16 PM
