GD idsi to ivtec swap. Help.
Old Jan 4, 2023 | 09:48 AM
Pirty's Avatar
Hello from the Philippines. I know this has been discussed here already but I can't seem to find the link. I currently own a 2006 GD which I race in Rallycross . In my bracket we race 1300cc and below displacement. All normally aspirated. My engine is a stock 1300 idsi. I wanted to do an L13A ivtec swap. My only problem is that most of the engines available here are all automatics. Will there be a problem if I use the engine with the ECU ? Considering that the ECU is from an automatic tranny?
Also, will the ivtec head be compatible with the idsi block if I go the head swap route?
Thank you for your help. Cheers!
Old Aug 19, 2024 | 01:47 PM
DirtCheap's Avatar
No idea, but how did you go about mounting the back mud flaps? They look great. Good luck!
Old Aug 25, 2024 | 09:54 PM
Jared592's Avatar
Looks like fun! An engine swap seems like a lot of effort for what looks like a 12hp difference between the DSI and the VTEC 1.3L engines. Perhaps you could just do some (naturally-aspirated) mods to narrow the gap a little, e.g. porting/polishing on heads?
knope
Aug 7, 2021 07:20 AM
Bend
May 9, 2019 10:12 AM
c45s
Nov 29, 2017 06:35 AM
k24a2fit
Aug 1, 2014 09:21 PM
GTornado
25
Jun 16, 2010 03:56 PM
