JDM Taillights Compatibility for my GD5
Old Apr 21, 2024 | 06:40 AM
jazzgd5's Avatar
Post JDM Taillights Compatibility for my GD5
Hello All.
I have a European Honda Jazz and the chassis number is GD5, comes with the 1.2 engine and is the base model pretty much for EU market.
I'm looking at some JDM Taillights to enhance the look of my Jazz, so far finding ones that are £100+ on UK Ebay and ones that are under £40 on auctions in japan.
Im wondering if these would be compatible with my GD5, as I am not seeing my chassis code mentioned anywhere and so some of you may say well its just not compatible, there are a few reasons that lead me to believe they might be compatible:
1. There are no noticeable differences with taillight housings or features within the taillight between models.
2. The major differences between chassis codes are the engines, so I wouldn't think that the taillights would change at all.
3. Since the GD5 is an EU model, the Japanese auctions may only recognize the Fit models, where there is no GD5 Fit.
Now, a good way to find out about true compatibility would be checking the manufacturing part, but I don't know where I can find the part for my specific GD5 model.The part model for the JDM tailights are: Ichiko 4995
Would appreciate any knowledge regarding this!
Old Apr 21, 2024 | 01:25 PM
Hootie's Avatar
I wouldn't worry about the physical shape of the tail lamp assembly since GD light housings (and their mounting point on the chassis) are the same design, globally.
Wiring is the real question as there is indeed a socket difference between LED and non LED lamp assemblies.
Its been documented long ago on this forum (roughly 15 to 17 years ago) that you'll likely need to unclip the tail light harness from the were it mounts in the hatch/cargo area to you give yourself some additional slack. Following that, if your Jazz has halogen upper and lower brake lights like the US specs you'll more than likely have to swap and repin those tail light connectors on the chassis harness to work with the Japan spec lights. I for sure had to do that with my US Spec Fit.
jazzgd5
Apr 21, 2024 06:45 AM
Pacemaker
Apr 3, 2017 08:55 AM
prossett
May 4, 2014 06:05 AM
braziers
Jan 29, 2009 08:35 AM
Dimer
Apr 2, 2008 03:02 AM
