I guess I didn't tighten down the plug enough?
Old Jun 30, 2024 | 09:37 AM
Andrew Kairis's Avatar
Cylinder 1 and 2 coils look like this
Car runs ok, small intermittent stutter at idle but fine otherwise.
I just replaced the plugs but if the old ones were not tight enough they were like than for 50k miles.
Just did a valve lash adjustment... Exhaust was all too tight.
3 and 4 still look brand new.
Old Jun 30, 2024 | 08:48 PM
Tecrun19's Avatar
What torque number did you tighten them to?
Old Jun 30, 2024 | 09:05 PM
"Feels tight !!don't strip the aluminum!!"
Clearly perhaps I underestimated aluminum
Old Jul 7, 2024 | 07:19 AM
john380's Avatar
Torque spec is only 13ft lb. Most likely the coils are failing. My coils looked similar when my Fit developed a mis-fire.
Old Jul 10, 2024 | 07:50 PM
Tecrun19's Avatar
Ive seen people quoting 20ft lb but I couldn't find any official documentation (at least that I can access). I did find this TSB for the 08 accords that mentions 16ft lbs and thats what I went with (https://static.nhtsa.gov/odi/tsbs/20...42434-9999.pdf) page 13.
I would first try replacing the boots of the coils (part number NGK 59024) and cleaning the bottom of the coils. Some videos on youtube show this whole procedure.
Old Jul 10, 2024 | 07:59 PM
Thank you!
The plugs I pulled all looked the same and honestly looked fine, but I hope I'll never have to do anything with them every again having replaced with NGK iridium at 177k
danielj982
Apr 25, 2023 01:32 AM
dgcx
Feb 16, 2023 02:00 AM
Dom Romer
May 31, 2020 08:34 AM
Lucas1976
Jul 5, 2018 12:01 AM
Spacecoast
Mar 14, 2018 11:50 AM
