weird sound coming from front
Old Sep 5, 2011 | 08:48 PM
fitster's Avatar
i noticed this today
i hit about 40 kmph and release the throttle sounds like a knocking coming from one of the front wheels
when i hit the throttle the sound disappears
the faster i go when the throttle is released the sound is louder
i originally thought it was my wheel bearing
but when i jacked up the car gave the wheels a good shake they where solid
any ideas???
Old Sep 6, 2011 | 05:10 AM
Black3sr's Avatar
any ideas???
How old is your car? How many kms? A very noticeable knock? May want to have a tech listen to it. Then again could be the neighbours cat.
Old Sep 6, 2011 | 02:30 PM
fitster's Avatar
08 Sport
WiTh 62500kms
Old Sep 6, 2011 | 04:54 PM
Krimson_Cardnal's Avatar
Wheel lugs are tight on? Does it change w/ directional changes, as in slalom back and forth? With a full steering lock in both directions, low speed in a parking lot, do you hear anything? Bad/worn CV joints might produce a clicking type noise under these conditions.
Old Sep 6, 2011 | 08:45 PM
mahout's Avatar
any ideas???
First, merely shaking the wheel won't identify a loose bearing. If it did you're likely stranded somewhere. I don't think its a worn bearing either.
though it might be. Only bearing inspection would tell.
It appears to be something caught in the wheel or disc brake. When the throttle is released the wheel/tire experiences a drag and something could be reversing direction or location that knocks. Does this knock appear to happen once per wheel revolution or more often? If its once per revolution its likely associated with the rotor or hub; is more often its more likely related to a spoke.. Since it doesn't happen when the wheels revolve 'under power' but does when not under power, I'd look for something 'pointing forward so it has interference in reverse. A stick could be the source. It could also be a misbent caliper backplate coveror even the shround that contacts a rotor. It could be a loose brake pad that 'waffles' in the caliper so make sure thae pads are properly secured and clean.
Not hearing the noise and potential location thats the only advice I have but you should attend to removing the sound quickly. It could be serious.
And possibly a loose fenderwell liner. That would easily slide one way and patter the other though iyt should 'buzz' when the wheel revolves forward.
good luck.
Old Sep 7, 2011 | 12:47 AM
fitster's Avatar
ok drove the car today
slow speeds slow clicks
faster speeds faster clicks
left turns in parking lot light clicking noise
right turns in parking lot louder clicking noise
so ive narrowed it down to a few things
worn brake pads
cv joints
large rock stuck in tire( theres no rock)
Old Sep 7, 2011 | 12:50 AM
somaFIT's Avatar
maybe broken axel? did you lower your car? check the cvJoints
Goodluck
Old Sep 7, 2011 | 10:52 AM
mahout's Avatar
worn brake pads
cv joints
Now I settle on a worn cv joint. A rock in tread would knock no matter whether under power or not. It could be pad chatter but its more likely in my opinion cv joints.Long distance diagnosis is always tentative. Hands on is needed.
Old Sep 7, 2011 | 11:00 AM
BlackPearlFIT's Avatar
bearing possibly...
Old Sep 7, 2011 | 12:48 PM
worn brake pads
cv joints
Take a peek behind front wheels and check the inner and outer boots for cracks.
Your Fit actually doesn't have cv joints, but a drive axle w/ inner and outer joints similar to u-joints.
I would suspect the right outer, but only a qualified inspection/diagnosis will tell you.
And it still could be a bearing, but I think not.
Keep us posted on your progress - it's nice to hear what it actually is ;-)
Old Sep 7, 2011 | 12:53 PM
Subie's Avatar
So true... My vote goes with the cv joint also with a 2nd on bearing.
Old Sep 8, 2011 | 02:41 AM
fitster's Avatar
update
drove to work in the morning same old clicks
after work started to sound wierder at a complete stop the right front creeks and scratches
almost like a grinding noise
looked at my right front rim and there seems to be alot of rust dust collecting on it
where as the left side is all clean
its now thursday tomoro after work friday ill be seeing my mechanic should find out then hopefully
Old Sep 8, 2011 | 02:57 AM
I now see a brake job in your future....
Old Sep 8, 2011 | 03:32 AM
doctordoom's Avatar
Supervillain
how many miles do you have on your car, and have you ever had the brakes bled, or changed the brake fluid?
Old Sep 8, 2011 | 02:53 PM
Subie's Avatar
Yup, from your updates, all indications point to a brake job...
Old Sep 9, 2011 | 09:38 PM
fitster's Avatar
Yup it was brakes but I did have a small pebble wedged in my pad so that's what made it noisier
Now just waiting to get my car back from getting all her fluids changed
Sometime next week new spark plugs and she should be running just like she did when she came off the show room floor
Old Sep 9, 2011 | 10:27 PM
Subie's Avatar
Cool! Now you're good to go!
Old Mar 7, 2016 | 10:34 PM
seeyalaterbye's Avatar
I have this exact symptom. I'm already planning on placing my rotors pand and shoes in a little over a week. Hopefully this is the problem.
Old Jul 12, 2024 | 12:46 AM
lvillalta's Avatar
Wow interisting, I just bought the whole mount support, I have the same symtop I will see if it the same solution. I do a little bit of mechanic by myselft.
Yeahhhok
Jun 21, 2018 12:31 AM
Yeahhhok
May 31, 2018 11:43 PM
kona.oliver
Mar 24, 2014 09:36 AM
toomuchjoy
Jun 10, 2012 09:31 AM
aerorea
May 15, 2005 07:30 PM
