Drain fuel from tank?
Old Oct 9, 2024 | 08:06 PM
Joshuahondafit's Avatar
How to drain fuel from tank? I'm thinking I can remove fuel pump and use that space to access the tank with a siphon hose. Would that work? Any better suggestions? Thanks
Old Oct 9, 2024 | 11:23 PM
Drew21's Avatar
That's what I would do.
If it was me, I would remove one or both front seats for easier access and to make sure no gas gets on the upholstery. Removing the seat(s) will also make it easier to cover/protect the carpet.
If you attempt to remove the seats, unplug the battery, pull the four seat anchor bolts, and then lean the seat backwards a bit to give you access to the electrical connections.
petejones
Mar 3, 2024 09:27 AM
suburban_caveman
Jan 7, 2016 08:34 AM
akcapfit
Jan 21, 2010 05:09 PM
ken_vs_ryu
Apr 1, 2009 09:08 AM
supaumar
Jan 21, 2009 08:56 PM
