2004 GD1 Jazz - Fault Code 8 TCD Sensor?
Old Aug 30, 2025 | 08:14 AM
L_Rawlings's Avatar
The check engine light has been on intermittently for a while. When the light is on, the engine 'hunts' on idle but still drives fine. If I unplug the battery, the light will go off for maybe 1 or 2 trips but then come back on. While it's off, it idles fine but when on it will hunt again on idle.
I've pulled the CEL code by jumping the diagnostics plug and counting the CEL flashes. It's fault code 8 which I believe is TDC (Top Dead Centre) sensor.
Has anyone had this error before on a Jazz and fixed it?
What I've tried already:
  • New Cam Sensor
  • New Crank Sensor
  • New Spark plugs (they were due anyway)
  • Cleaned out the EGR
  • New oil and oil filter (this was due as well)
I read that this error is sometimes caused by timing being out due to a stretched chain but don't want to go down the route of chain replacement unless it's 100% the cause as that's a much bigger job!
I also read on some older Honda's the TDC sensor is inside the distributor but the GD1 Jazz ignition is ECU and Coil controlled so no distributor. Could it be a dud ECU or coil?
Any suggestions appreciated.
Cheers
L
mickteroo
Oct 10, 2023 07:44 AM
rglouc
Sep 25, 2023 08:53 PM
FITness69
Sep 21, 2021 04:06 PM
Hirvi
Nov 25, 2011 11:11 PM
redfit_pr
Jun 16, 2009 02:50 AM
