Cruise control doesn't work...what to do????
Old Oct 9, 2008 | 02:16 AM
FELIXY69's Avatar
hi guys
i have a problem which some of u could help me
my cruise control wouldn't let me set the speed but i can turn it on with the light on at the dash, but would set speed
what should i do ?
where can i look ?
where is the cruise control fuse located.....still can't find it.
thank you !
Old Oct 9, 2008 | 02:53 AM
storm88000's Avatar
Frequent FitFreak Poster
Fuse? First thing I thought of
Old Oct 9, 2008 | 06:27 AM
FELIXY69's Avatar
where is the fuse ??
i can't find it !!
thanks
Old Oct 9, 2008 | 10:04 AM
FitVic's Avatar
i dont know if this is gonna answer for you but i know for a few weeks i thought my cruise control wasnt working but then after a few trial & errors i found out that my left foot was BARELY touching the clutch so it made the cruise control inactive......... I'm stupid lmao!
Old Oct 9, 2008 | 10:50 AM
Fitcapo's Avatar
Just take it to a mechanic or the dealership if you don't know where the fuse is your best bet would just to let a professional do it.
Old Oct 9, 2008 | 03:51 PM
plus, i think you're still under warranty?
Old Oct 9, 2008 | 05:01 PM
GD3 FTW's Avatar
mine does this every once a while too
Old Oct 9, 2008 | 10:25 PM
FELIXY69's Avatar
my car is auto and since i have turbo...they dont' wanna warrenty it and i really don't want to drop the car off at the dealers....who knows what they'll do to it...right.
Old Nov 1, 2008 | 08:58 AM
FELIXY69's Avatar
i still can't get it fix....help !
Old Nov 1, 2008 | 12:20 PM
avcm's Avatar
Do you have LED tail lights?
Old Nov 1, 2008 | 12:32 PM
chimmike's Avatar
If you have any CEL of any kind, usually the cruise won't work.
Also, if the fuse was out, he wouldn't get the "cruise main" light.
Old Nov 1, 2008 | 03:17 PM
prelude_guy97's Avatar
Faulty ECU? It still could be possible that another fuse would used to provide the set point.
Old Nov 1, 2008 | 09:55 PM
polaski's Avatar
You could do what I did and put 69k miles on a civic without working cruise
Well if yours is USDM ... there is no cruise fuse. The DBW, remember? The ECU controls the throttle body ALL the time, just when you put it in cruise it ignores the go pedal and relies on the speedo input.
Something in your setup is making the ECU unhappy.
edit: aah mitsketa. British Colombia. That's still DBW isn't it?
Old Nov 2, 2008 | 11:49 AM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Having a turbo voids warranty on the cruise control parts?
Have you at least tried to take it in?
Old Nov 7, 2008 | 05:12 PM
E = Mc2's Avatar
My very first thought. I would guess that the answer is 'Yes'.
Old Nov 12, 2008 | 06:49 AM
FELIXY69's Avatar
what does LED tail lights have anything to do with cruise control ?
Old Nov 12, 2008 | 09:06 AM
Fit of RAGE's Avatar
what speed are you trying to set it at?
Old Nov 12, 2008 | 09:35 AM
FELIXY69's Avatar
120km..............
Old Nov 12, 2008 | 01:40 PM
E = Mc2's Avatar
IIRC, certain LED tail lights will cause the cruise to stop working. In essence, the system thinks that the brakes are applied and shuts off the cruise. The solution is to install a diode on the hot lead so the voltage will only flow in one direction... I'm certain that there is something about it on this forum or Honda-tech somewhere. In any case, I've read about this complaint in conjunction with LED tail lights on more than one occasion.
Old Nov 12, 2008 | 10:28 PM
FELIXY69's Avatar
i had led tails before and it works fine....
