Help: Belt and/or Pulley Squeak
Old Aug 11, 2009 | 11:20 PM
Marrk's Avatar
The Car: '08 Base Fit, manual trans., with 25K mi.
The Problem: Belt and/or pulley squeaking.
Symptoms:
--Engine temp doesn't influence squeak
--Air Conditioning on or off doesn't influence squeak
--When I increase RPM in neutral, I cannot perceive that the squeak is louder (all I can hear is the engine)
--I don't think the belt is loose, but there is no room to really get to the belt to check it.
--The squeaking is intermittent but is becoming louder and happens more often.
Solution: ??
Old Aug 13, 2009 | 05:44 PM
polaski's Avatar
Step one, check belt tension
Step two, check belt for damage/cracking in the ribs
Step three, replace belt
Step four, start checking pullies, it's usually the little ones that squeak
Old Aug 13, 2009 | 06:56 PM
Necos07's Avatar
Check ur belt, if its ok & tight see if there is brown residue on the belt. Sometimes water gets on ur pulleys & developes a slight film of rust on the pulley causing a squeak. Just take a bit of rubbing compound on ur finger & put it on the ribbed part of the belt, just on 1 little section, Whatever 1 finger covers & start car. REMOVE FINGER BEFORE U START CAR LOL
Old Aug 13, 2009 | 11:40 PM
Marrk's Avatar
Thanks, guys.
I can barely see the belt, let alone "inspect" it, but I'll get in there tomorrow and give it a try.
Old Aug 14, 2009 | 01:20 AM
kylerwho's Avatar
spoon fed
spray some lubricating oil on the belt to see if this kills the noise.
its not a lasting solution but it should do the job for now.
Old Sep 24, 2009 | 02:44 PM
Marrk's Avatar
Sorry to revive my boring little issue, but here's an update.
I've examined the belt and hit the belt and pulleys with WD40, but the noise remains. For the moment, let's say it's not belt/pulley noise.
I recently noticed this: When I engage the clutch, the noise stops. As soon as I lift my foot off the clutch pedal, the noise returns.
I don't know much about clutches and transmissions, so my question is: What could be making a metallic rattling noise that goes away when I push the clutch in?
Thanks for your thoughts.
P.S. Is there any way that what I am hearing is cam chain noise? Honda's are famous for crappy cam chain tensioners.
Old Sep 24, 2009 | 03:27 PM
throwout bearing maybe?
Old Sep 24, 2009 | 05:11 PM
sonicsc1's Avatar
second that
Old Sep 24, 2009 | 06:50 PM
Marrk's Avatar
So, if it is the throwout bearing, where is this leading to? Clutch slippage? Clutch failure? And what is the remedy?
Thanks.
Old Sep 25, 2009 | 06:29 PM
Marrk's Avatar
Is the pilot bearing the same as the throwout bearing? I'm looking at Page 12-13 of the Fit 2007-08 Service Manual.
Thanks.
Old Oct 2, 2009 | 11:46 AM
Marrk's Avatar
I made an appointment for next week with the dealer.
Has anybody here done any clutch work? If so, how long would it take to inspect the clutch bearings? Is opening up the clutch a long and difficult job?
Thanks.
Old Oct 2, 2009 | 12:36 PM
GD3_Wagoon's Avatar
i've swapped out the clutch a few times on my crx and it was cake. although, i've read that it's a little more involved on the Fit as the subframe needs to be removed to drop the trans.
Old Oct 2, 2009 | 12:39 PM
Marrk's Avatar
Sounds complicated.
Thanks.
Old Oct 2, 2009 | 03:03 PM
explosivpotato's Avatar
My car makes that very same noise. Its a noticeable whirring whenever the clutch is engaged (foot off the pedal) and slows down to a stop when you press the clutch. It's the throwout bearing, and I'm pretty sure mine is going because I beat the hell out of it (relatively, anyway). Somehow I'm still on the stock unit even though I'm putting down something like 65% over stock torque. Hopefully the warranty covers it for you.
Old Oct 2, 2009 | 04:31 PM
Marrk's Avatar
Yup, that's the noise.
So, how big a job is it to fix? Is this something that fails gradually or catastrophically? Will I make it to next Thursday?
Thanks, Potato.
Old Oct 3, 2009 | 01:08 PM
Marrk's Avatar
Originally Posted by Marrk
. . . Will I make it to next Thursday?
I know that sounds like a dumb question.
I guess what I really want to know is what scenario am I looking at? So far, the noise has gradually gotten worse. Will things progress slowly? Or will something suddenly fail and make the car un-drivable? What happens when the throwout bearing craps out entirely? The clutch stops working and you can no longer shift?
Thanks for any insight.
Old Oct 3, 2009 | 10:17 PM
It really isn't as serious as you'd think.. I've been driving like this for a year or so, and it hasn't gotten worse. The noise will gradually get louder until the bearing fails, so if it gets REALLY loud I'd worry, but a slight whir seems pretty innocuous. Try searching for "bad throwout bearing" on youtube for examples.
Old Oct 3, 2009 | 10:23 PM
Marrk's Avatar
Thanks, Potato. That's a bit of a relief to hear.
Thursday it goes to the dealer. Do you happen to know how extensive a job it is to fix?
Old Oct 4, 2009 | 11:59 AM
Well it's an integral part of the clutch, so probably a lot. I hear the clutch on the fit is an involved job, as the subframe is in the way of the transmission, so I'll just say be happy it's a warranty job.
Old Oct 4, 2009 | 12:02 PM
Marrk's Avatar
One last question: On a stock '08 Fit that has not been thrashed, just a daily driver, what would cause the bearing to fail? This has never happened to me before.
