Diy: Acura mdx map light roof console
well guys i had seen someone do this already w/ the cl map lights but i love my ray-bans too much lol
. so i went w/ an mdx concole instead.
lets begin.
so first i took the console and made a stencil for the hole i needed to cut.
measure 10 times and cut once i always say. once i knew the fit was good i started so solder 2 wires onto the console since i didn't get a plug w/ it.
since the console wasnt the same color (it was dark grey) i bought some paint to match it up.
once it dried i put it in the roof. NOTE*** i had to use the foam bloack that came out when i cut the headliner to create some room for the sunglasses holder. no cutting or anything just pulled the headliner down a bit and stuff it in between it and the roof. its exactly 2 inches just like the compartment is deep.
the console has 2 tabs on one side to hold it on so i only screwed it in by the lights. i used 2 wooden blocks and a paint mixer stick as a bracket for the screws and to keep to console from falling out. **sry no pics of that i was trying to beat the rain**
splice one wire into the red/wht wire on your dome light plug and the other to a ground. (i used the same as the dome light which is the screw hole for it).
finally put your dome light back in place amd enjoy
drop some comments and rep my way if you like
. so i went w/ an mdx concole instead.lets begin.
you can get the accord one also. and you don't have to paint
it. i did the same thing a while back and got one from an accord.
matches the interior pretty good.
i also think the odyssey has one also.
There are like 1,000 of these on eBay, you're gonna pay 3-6X more money buying one of them new. Honda's price is ridiculous for anything with homelink.
accord one works too i got mine on ebay also. you're better off going that route. im pretty sure the accord has no homelink. the cl has a similar one too not sure if it has sunglasses tho. or take a trip to your local junkyard :/
the homelink is just a 12v power and a ground. you should be able to splice into the map light wires for that.
Follow the good advice given to me, get the MDX with the Homelink. It doesn't add anything to the price and the buttons are small enough that no one will ever notice. I am going to experiment with making mine functional, just because I think a Fit with a working Homelink opener would be cool. I'll be installing mine tomorrow, along with four new speakers Woot!
You mean the third pin that goes to the OE wiring in the MDX right? And did you run a wire directly to ground from the console or did you splice it into the dome light wire? My console map lights aren't working and i want to make sure that I wired it the same way you did...
