Turning Off AC When In Windscreen Vent Mode
Old Feb 8, 2010 | 10:36 AM
trashercan's Avatar
You may all know that as soon as you set turn the window defroster / demister on the AC is engaged. This is stupidly un-necessary and wasteful on fuel (AC light doesnt come on).
My idea is to put an inline switch in the AC circuitry and then manually be able to engage the electrical circuit for this (and the main AC function, but not bothered by that side of things).
Has anyone got ideas where I can interrupt the circuit for the AC and insert a switct that I can mount somewhere on the dash ?
Old Feb 8, 2010 | 12:09 PM
spreadhead's Avatar
Procedures are posted, use SEARCH.
Old Feb 8, 2010 | 01:33 PM
trashercan's Avatar
Already searched found nothing
Do you know whether its in this forum or the Second generation or the link to it ?
Old Feb 8, 2010 | 01:41 PM
Perrenoud Fit's Avatar
It should b the same with a GD3 or GE8 you are just breaking 12v to the compressor.
Use a multimeter to find the wire that triggers the comp. and u can break it there or follow it back to the contoller @ the dash and break it there. W2TW fuse the power wire from the comp. trigger 2 the switch over kill maybe but better safer than sorrier.
Hope this helps.......................
Old Feb 8, 2010 | 02:11 PM
Antpwny's Avatar
How about helping out a noob instead of just yelling at him to search. It's buried on page 6 of a 130 post thread.
https://www.fitfreak.net/forums/108654-post101.html
There you go OP
Old Feb 8, 2010 | 02:54 PM
Chazzlee's Avatar
Okay, this cuts out the AC from coming on when you set the windshield circular defroster sw on. Certainly useful for my winters in NJ, I suspect.
But how does this work on a hot rainy day when you do want both the demister and the AC to be on?
Old Feb 8, 2010 | 03:25 PM
spreadhead's Avatar
Press the AC button to activate the compressor.
Old Feb 9, 2010 | 05:25 PM
Post Dehumitification drys the windsheild
The A/C Dries the air; think of it like this if you had a ball of air the size of a basketball and is at 100% R/H at 70 degree and this sphere of air goes through the eveporator coil the action of the cold coil shrinks the basketball size to a baseball size at 42 degrees and in the process the 100% R/H gets squeezed too. Henz the water dripping out onto the street from you coil. Okay now the heater coil has hot water in it and the baseball size of air gets exspanded back to a basketball size but the R/H does not increase because the cold coil squeezed it out and the water vapor is not in the sphere anymore it's on the street. Now if you have visuallized the changes to this point........ with the air now being expanded to it's original size and the water vapor out, it's dryer and can absorb the moisture forming on the windsheild. And that class is dehumtification................ cool class over
Old Feb 9, 2010 | 08:14 PM
trashercan's Avatar
Thanks everyone who posted with useful information. Removing the connector from the vent control was completed in 5 minutes.
Anyone point me in the area of removing the HVAC controls completely 'on their own' so I can get at the main cable going to the radio ? I want to plug in-line a Parrot bluetooth cell phone adapter and dont want to take the radio out (as per most of the instructions here).. I guess that with the HVAC controls out, I can reach up and disconnect the cable, collect the parrot cable to it and then to the radio.
Cheers in advance.
htewam
Sep 25, 2024 03:26 PM
Roger's Fit
May 28, 2021 11:55 AM
jlatus
Oct 7, 2012 10:06 AM
k-alt
Jul 9, 2012 11:01 AM
wacky wick
Aug 24, 2010 05:59 PM
