Seibon CF hood ?????
Old Apr 24, 2010 | 10:54 PM
Cat's Avatar
Cat
I knew it was going to look great with the carbon fiber hood, I just wish I was able to get my car close to being so presentable.
Thanks! It is funny how at first I wanted white rims and never had any thought to do the hood but one night I could not sleep and I just started thinking black rims - CF hood - yikes! Could I do it and how would it look. This car has taught me a lot about taking your time and doing my mods one item at a time. It has taken me 3 years to get it to this and now I can just enjoy it and have fun with it.
Cat :x
Old Apr 24, 2010 | 11:12 PM
Texas Coyote's Avatar
I think it gets easier to calmly envision and make a decision as we acquire wisdom from experience.... I am getting ready to spend a chunk of change for an under the hood upgrade..... My body just isn't over the last time I had to crawl under and wield a wrench for a suspension upgrade.... I hope to get around to prettying it up one of these days.... I'll be looking out for future modifications that you make to your Fit.
Old Apr 24, 2010 | 11:14 PM
Btrthnezr3's Avatar
If you need help, Coyote...you know how to get in touch with me ;-)
I'll help ya any way I can.
And Cat, I think the color scheme you have going on your car is perfect. It looks great!
I am going for white/black/red type theme myself.
Old Apr 27, 2010 | 09:14 AM
mgutt's Avatar
Originally Posted by Cat
Also the clips for the rubber piece on the hood does not match the holes in the front of the Seibon hood - is the rubber stripping really needed. It seems to fit really well and tight there so I don't think it will be an issue.
They don't match? And what if the hood falls down / if I close it with to much force?!
Old Apr 27, 2010 | 04:09 PM
grtpumpkin's Avatar
The trick with CF is to just eaaaaaaase the hood down and then push it the last bit to a solid latch. Slamming it down like you would the OE piece is a sure-fire way to crack the laminate, rubber strip or no rubber strip. Cat the car looks fabulous, now you just need more low! LOL Sorry I just had to say it before someone else beat me to it. I would paint the foglight housings black as my next mod if I was you. They are the other part that takes a beating from the roads and the black is easily touched up, unlike the Milano Red.
Old Apr 27, 2010 | 04:24 PM
Ditto on black fog light housings..... I was thinking that since the new hood was installed and hoping to see a post from Cat saying something about doing it.... I have some rubberized black undercoating to do mine with.
Old May 4, 2010 | 10:25 PM
xenjin's Avatar
What year?
Hi,
Looking to get a carbon fiber hood for a 2002 Fit but the most of the manufacturers have 2007-2008 as the earliest make. Will this fit the 2002 model?
Old May 5, 2010 | 12:52 AM
Jordy's Avatar
what you guys think???
lol
Old May 5, 2010 | 01:52 AM
lol
That is the hood I would get if I was to get a carbon fiber hood.... My car would almost be a twin of yours with one.
Old May 5, 2010 | 04:04 AM
mgutt's Avatar
2002? So you have the european / jdm version.
You can buy the two different jdm seibon hoods only (oem, mugen style).
Old May 5, 2010 | 10:31 PM
xenjin's Avatar
Thanks MGUTT
Yep I have an imported Japanese GD1 L13A 2002 model... just went on Seibon's website and checked the Fit-JDM and am seeing as early as 2003 for the Mugen and OEM like u said. There weren't any changes between 2002 and 2003 right?
Old May 6, 2010 | 04:10 AM
  #32
mgutt's Avatar
Nope.
This is the complete timeline of the japanese Fit:
Timeline
* 2001 (2001) June 21: Presentation. Next available starting June 22. At first "W" · "A" · "Y" was the third-grade system.
* 2002 (2002) December 9: L15A Type 1.5L SOHC VTEC (110PS/14.6kg · m) S +7 Hondamaruchimachikku engine speed mode [5] equipped with "1.5T" the add. Optional 15-inch car manufacturers and rear brake disc type. "1.5T" Hafusheidouindou only manufacturer as an option, automatic air conditioning, which contains a mirror electric pack "L" package and large Terugetosupoira [6] and set.
14 o 11: "1.3A" and "1.3W" some improvement. Option is set to HID headlights and Haimauntosutoppuranpu manufacturers, answer back function to add a keyless entry.
* 2003 (2003) October 4: 1.3L · FF improved the car's engine "super - low emission" certification.
o October 21: Some improvements. The interior "Shifonbejuinteria Set" ("1.3Y" excluded). New "Honda Sumatokadokishisutemu (with immobilizer function)" set [7]. "Ultra - low emission" expanded certification of all types. Furthermore, Suspension, Furontosutapiraiza size up well with improved ride comfort and handling stability improvements floor, than realized in the steering of the natural capacity of up Pawasutearingumota and low friction. "1.5T" The car was set FF Riadisukubureki additional (optional 15-inch and set.)
o December 25: some improvements (launched January 13, 2004). To add color and body, meets 2005 emissions standards. 1.3L cars "emission standards 75% lower than 2005 (☆ ☆ ☆ ☆)" a, 1.5L cars "emission standards 50% lower than 2005 (☆ ☆ ☆)" acquired, respectively.
* 2004 (2004) June 10: Minor changes. Called a "medium term" model. Grade 1.3L car sporty "S" added. Conventional car 1.5L "T" has been abolished, 1.3L cars of the same Supotiguredo "S", basic grade "A", senior grade "W" grade structure and three, "W" and "S "The FF 5 MT-speed cars specifications added. S +7 Hondamaruchimachikku speed mode is an improved paddle-shift. Change the front grille and bumpers, LED taillights and brake lights (all models), LED Doamirauinka (part) supported. Renewed the meter, 1.5L cars will be self-luminous type. In addition, all models that were more highly efficient engine, "2010 +5% fuel economy standards" to achieve.
16 o 12: "1.3A" based, Honda Sumatokadokishisutemu (with an immobilizer function), Doamirauinka (LED), well equipped and feature rich Eakurinfiruta "Metallic Kurisutaruakua" set a special edition dedicated body color "1.3A welcome edition" release.
* 2005 (2005) April 14: auxiliary leg drive to drive with both feet moving for disabled persons arms "Honda · Franz System" Set-equipped vehicles.
o August 12: Minor changes. Called a "late" model. Front grille, modified front and rear lamps around the system. The Supotiguredo "1.3S", "1.5S" is expanded to 14-inch diameter front disk brake, Riadisukubureki (Previously, 1.5L FF Maker option only) and 15-inch standard equipment From devising the possibility of such discrimination, 4WD vehicle was abolished. Also, Kiresushisutemu "Honda Sumatokishisutemu" Nearby, "1.5W" standard equipment, "1.3/1.5S" and "1.3W" option set. The "emissions 75% lower than 2005 standards (☆ ☆ ☆ ☆)" approved by the expansion of all types. Body color special edition "1.3A welcome edition" was set color "Metallic Kurisutaruakua" were added, including four-color.
* 2006 (2006) December 21: A New Grade "1.3A" based, privacy glass and electric door mirrors store (LED without Doamirauinka) as standard equipment, what equipment 直Ta see "1.3 AU "Add. At the same time "1.3AU" and "1.5A" based on "Honda HDD Intanabishisutemu" special edition featuring "HDD Nabiedishon" release. In addition to HDD car navigation antenna on micro-1.3L, 1.5L cars are electric retractable Rimokondoamira (LED with Doamirauinka) has additional equipment such as high performance deodorizing filter Arerufuri.
* 2007 (2007) June 14: special edition "1.3A HID Edition", "1.5A Comfort Edition" released. The former HID headlights, privacy glass, a micro-antenna, the latter Automatic Climate Control, equipped with immobilizer. Electric Retractable Rimokonkaradodoamira two more common types (LED with Doamirauinka), which also features the new features are enhanced Arerufuri filter. In addition to the above equipment Intanabishisutemu Honda HDD-equipped "1.3A HDD navigation HID Edition", "1.5A HDD Navi Comfort Edition" released simultaneously.
Source:
Japanese Wikipedia (online translation)
Old May 6, 2010 | 08:23 PM
  #33
xenjin's Avatar
Great stuff... thanks again Mgutt
Old May 6, 2010 | 10:27 PM
  #34
score04w's Avatar
lol
is that the vent that runs all the way across the hood?
and are you rocking no front grill?
like the car. Not too crazy about the hood and grill situation. I need a pair of black headlights for my ssm, and tints and visors though.
Old May 8, 2010 | 07:04 PM
  #35
Roo's Avatar
Roo
my seibon hood had some clear coat problems
Old May 9, 2010 | 05:39 AM
  #36
mgutt's Avatar
I hope not like that:
YouTube - Carbon Creations Carbon Fiber hood clear coat FAILURE!
Old May 9, 2010 | 05:46 AM
  #37
kelsodeez's Avatar
UNBANABLE
clear coat the hood and you will have zero discoloration problems. OR you have to polish and wax it at least twice a week and try to keep it out of direct sunlight as much as you can.
Old May 9, 2010 | 12:59 PM
  #38
Jordy's Avatar
that that vent is almost across the whole thing, as for the grill, i got my red badges stolen twice so i just thought i would take the whole thing off. but i do have a mugen grill sitting at home waiting for it to get painted...
blackndecker
Jul 24, 2010 10:46 AM
fit4afit
20
Mar 10, 2010 10:48 AM
taFITta_sport
Sep 28, 2009 05:45 PM
actonimpulse
Jun 15, 2007 02:16 PM
Jimmy101
Jan 13, 2007 02:19 PM
