2007 weak battery
Old Jul 1, 2010 | 01:21 PM
leisuredress's Avatar
2007 weak battery
Twice in the past couple of weeks, my battery has died after leaving the radio on for my boyfriend while I run into the store to get something (3-4 minutes tops). Obviously, I won't be leaving the radio on anymore. But my question is, do I need to replace the battery? Or is this just a quirk with the battery? I do not have any special stereo equipment or anything that would be putting more of a drain on the battery. The car has 40k on it.
Old Jul 1, 2010 | 02:42 PM
Jimmy101's Avatar
since you have an 07 and probably the original battery, its about time for a new battery.
Only the dealer sells the 151r, but a 51r will fit, unless you have
an air intake system.
Old Jul 1, 2010 | 02:44 PM
gd3vbp's Avatar
You can always have the battery tested, but if its dying after 3-4 minutes odds are you need to replace it. Probably sooner rather than later.
Old Jul 1, 2010 | 03:35 PM
spreadhead's Avatar
I have a 51R in my 07. Cheaper and better than a 151R (factory battery).
Old Jul 6, 2010 | 12:46 PM
sonicsc1's Avatar
second that just put a 51r in big difference
Old Jul 10, 2010 | 01:49 PM
Mike413's Avatar
I own an '08. factory battery & I've been having problems lately w/ the starter turning over. Mind you, No a/c was or is on. I'll keep the key on the 1st turn w/o or w/ the radio on & it'll just turn over. I heard that I'm going to need a new battery b/c the factory one is to weak..I find that idiotic.
Anyone else w/ this problem?
Austin Healy
Apr 16, 2024 06:41 PM
Zero2Hero
Feb 9, 2019 10:03 PM
jchcmax
Jan 5, 2014 02:54 PM
revd34
Jul 30, 2009 06:43 PM
piclistguy@yahoo.com
May 4, 2005 11:16 AM
