p0451 Evaporative Emission Control System Pressure Sensor
Old Aug 8, 2010 | 03:23 PM
coldstorage5's Avatar
Hello, My check engine light came on. I have a scangauge. The code is
Evaporative Emission Control System Pressure Sensor.
Any Ideas here. Is it the charcoal box? I did fill the tank today. I always fill it up, and stop when the pump stops at the first click so I dont top it off.
Suggestions??
Thanx for your help
Old Aug 8, 2010 | 09:39 PM
No Ideas people,.....
Old Aug 8, 2010 | 09:48 PM
spreadhead's Avatar
I have an '07 factory manual. The canister is located under the car in front of the tank. The pressure sensor is on the left (driver's side) rear of the tank. Note this is for an '07. The manual says to first reset the code and see if it reappears. If it doesn't take no action.
Old Aug 8, 2010 | 11:26 PM
Reset
Ok, Thank you for helpin out,..... I did reset it, If it reappears then what??? Change the sensor? Or Canister? Or leave it??
Old Aug 9, 2010 | 07:41 AM
spreadhead's Avatar
Check for loose connections. If connections are good change sensor
Old Aug 10, 2010 | 07:42 PM
I disconnected the battery, Which eliminated the Check enginelight.
Opened the gas tank, ny leaving the cap open over night.
I have driven 100 miles and no ck engine light. Hopefully it was the cap., or Maybe I need to stop filling the tank all the way to the first click.
03DSM-RSX
Sep 16, 2023 08:35 AM
Hirvi
Nov 25, 2011 11:11 PM
BansheeScratch
Nov 17, 2011 01:31 PM
07FitSBOM
May 17, 2008 09:09 PM
xcurt15
Jul 5, 2007 04:49 PM
