Would bad ground cause idle misfire?
Old Apr 23, 2012 | 12:22 AM
Texas Coyote's Avatar
Ford products had a puny + battery cable that wouldn't turn the starter motor fast enough to start the car.. The problem caused a lot of starter solenoids to burn up.... I wouldn't buy a grounding kit but I do have heavy gauge cable that is going to be replacing the little cables since I will have a small Deka battery, more electronics and water/methanol squirting into a couple of 2 or 3 places to see if it will add more power.
Old May 1, 2012 | 02:41 PM
cakacon's Avatar
I think i can easily say its probably the coil packs which is the most common fit problem by far.. I would do these before ripping your car apart
beeblebrix
Aug 4, 2017 02:03 PM
Stingray
Jan 19, 2016 09:13 AM
canbac21
Jan 18, 2016 05:50 PM
Marrk
Sep 20, 2013 11:07 AM
junior40er
Aug 27, 2013 04:24 AM
