lol or end life now? Just installed 4 new coil packs and AIT sensor, idle still sucks
Old Aug 8, 2012 | 06:21 AM
accordguyintake's Avatar
The car drives WAY better, smoother and more powerful and gone is the stutters after replacing the 80k old original stuff... But bad idle remains. Any ideas? Idle just shoots up and down, goes up, starts slipping, then falls almost dead and the engine abruptly picks it up, then it just does that on and on. I'll take a video in the morning and post it up, although I think everyone knoes what it's like Honda needs to seriously figure out what the actual cause of this is, and stop ignoring us or sending us on the runaround. It's getting old
Old Aug 8, 2012 | 06:52 AM
macbuddy's Avatar
Have you checked your plugs already?
I noticed smoother idling right after installing a new set of plugs (Denso IK22s set at a .032" gap). Before getting new plugs however, I would just try closing the gap down first, to see if that helps.
Old Aug 8, 2012 | 07:45 AM
pokems23's Avatar
June 2007 3rd Place Fit of the Month Winner
Have you tried going the alternator route?
Old Aug 8, 2012 | 07:51 AM
Remould's Avatar
Could it be a problem with the IACV (Idle Air Control Valve) on the throttle body?
I once started my Civic with the IACV plug removed. The car didn't idle at all well. Revs would rise then drop, rise then drop etc...
Maybe you could pull the plug on the valve to see if it gets worse? If nothing changes, that may be the cause.
Old Aug 8, 2012 | 09:33 AM
Btrthnezr3's Avatar
Have you done an idle relearn?
Let the car sit over night.
Unhook the battery.
Discharge battery thru brake pumping and maybe wait 10 min.
Hook up battery.
Do not at any point touch the throttle.
Start the car.
Let it run for 20-25 minutes.
Fans should kick on.
Turn car off.
Restart as normal.
My S was having a weird idle issue and was surging and dying after work that was unrelated. Did the idle relearn and poof. Back to normal.
Old Aug 8, 2012 | 09:45 AM
SHG_Mike's Avatar
Have you adjusted the valves?
Old Aug 8, 2012 | 01:25 PM
I had IK22s installed about 10k miles ago
No valve adjustment yet, I tried letting the car run and figure itself out, but I'll try doing it again.
Someone just suggested checking an idle valve so Im gonna run to my car and see if I can find it right now
Old Aug 8, 2012 | 01:58 PM
it appears to be smoothing itself out... we'll see how it goes
Old Aug 9, 2012 | 08:36 PM
Carbuff2's Avatar
That's cause the ECU is finally learning the idle.
Put a quick end to your misery. Do the Idle Learn as Btrthnezr3 said. It's worth the 20 minutes.
One additional step: The factory manuals always say to turn the ignition to the RUN position (engine off) for at least two seconds before starting the engine.
PS If you have the factory radio make sure you have the Access Code so you can re-program it after you disconnect the battery.
Old Aug 9, 2012 | 10:48 PM
SilverBullet's Avatar
Dirty throttle body can cause a rough idle. Clean the throttle body and adjust the valves.
Old Aug 10, 2012 | 01:11 PM
^ it should either be that or a bad 02 sensor.. I have a greddy turbo kit installed so I think oil is being blown around everywhere and getting on stuff
Old Aug 10, 2012 | 07:19 PM
Btrthnezr3's Avatar
Please try idle relearn too.
Old Aug 12, 2012 | 05:56 PM
mahout's Avatar
Check the fast idle circuit, both computger and idle screw. usually the idle shoulfd be about 1500 til the engine warms some.
Old Aug 12, 2012 | 06:06 PM
mahout's Avatar
If you have OBD ll checker check diagnostics for P0506 code. Dealer will have to follow the manual.
MIS-FIT
Jun 27, 2018 09:57 AM
noelrobles22@gmail.com
Nov 20, 2017 11:26 PM
Mike Runge
Jun 11, 2017 11:46 AM
UnicycleWheelie
Mar 8, 2014 11:28 PM
junior40er
Aug 27, 2013 04:24 AM
