led fog light bulbs ebay fittiment?
Hey has anyone bought these led h11 fog light bulbs off of ebay,
there are a few different kinds with different numbers of led's i was wondering which ones might fit, because the fog lights have that metal ring, that surrounds the bulb and limits the width of the bulb you can have. for example: http://i.ebayimg.com/t/H11-Pure-Whit...OfU!~~60_1.JPG |
I wouldn't waste my time unless I saw a measure of the lumens of stock vs ledproduct in various areas of the illuminated light pattern in front of the car; or if someone recommended them to you based on their purchase experience. All other specs like wattage and absolute bulb lumens is just noise.
Originally Posted by CTCT
(Post 1170507)
I wouldn't waste my time unless I saw a measure of the lumens....
Ever passed a German car with ONE brake light on, all the time? That's the REAR FOG LAMP working for them (turns on with the front fogs). |
Originally Posted by Carbuff2
(Post 1170552)
Remember, FOG LAMPS are not designed to light up the road. They are to be used so that oncoming drivers can see you in poor visibility conditions.
Ever passed a German car with ONE brake light on, all the time? That's the REAR FOG LAMP working for them (turns on with the front fogs). I was foolish enough once to buy an led brake bulb from ebay and it was crap. Brightness was about 50% of tungsten filament bulb. |
(Post 1170552)
Ever passed a German car with ONE brake light on, all the time? That's the REAR FOG LAMP working for them (turns on with the front fogs). There are GREAT quality, add-on after market fog lights and driving lights, but the Fit does not have any place to mount them. The plastic "bumper" won't work as a mounting surface. All off-road vehicle and true sports car drivers know the real value of real fog lights. Fit fog lights are just pretend- only there for looks and to fool the buyer. Oncoming drivers see you from your headlights, because the fog lights will not come on with stock Fits and most other fog lamp-equipped USDM cars unless the headlights are on. For the OP, the eBay LED bulbs are probably junk just by their appearance, but I don't know that for a fact. If you are willing to risk a few bucks in an experiment, why not try them and tell us what the quality is? Maybe you can help some poor, slave-labor Chinese family out by increasing the sales if the lights in the ad actually do work. Just remember that the lamp assembly on your Fit is not made to produce long range, properly focused light. The LED's are almost guaranteed to be weaker in output than the stock halogen bulbs. Fog light/driving light output is regulated by power consumption of the bulb. 55 watts power is the limit for add-on lights for highway use in CA (may have changed by now, but I got a ticket decades ago for ignoring the law at the time). LED's can produce much more light than halogens, at far less electrical power. A 30 watt LED flashlight can produce 6000-8000 lumens using LED bulbs. Stock Fit fog lights probably produce under 200 lumens. Any more than that would melt the plastic housing with halogen bulbs. |
i should have stated that it would only be for appearance purposes, not for any kind of lighting performance, just to look better, and run cooler/much less watts.
Originally Posted by m-man@sbcglobal.net
(Post 1170601)
Hello
I installed those LED bulbs in my Fit, nice look day and night, just that, nice look the illumination is poor. http://i.ebayimg.com/t/2x-cree-h11-6...(tQ~~60_12.JPG http://www.ebay.com/itm/2x-cree-h11-60w-High-Power-LED-Car-fog-running-light-bulbs-white-12V-24V-DC-/251384388998?vxp=mtr |
just wondering if installing these leds to our foglights, is a resistor required to prevent hyperflash of some sort?
No resistor required, but to prevent possible overheating you can use a 25W 8Ω (Resistor)
I used those LEDs without resistors without any issue, as recommendation before to buy them, ask to the seller about the warranty, those LEDs will give a better look to your FIT, better than STD bulbs, just the look, lighting power is not the same. Luis |
If you're looking for LED fog light bulb thats bright look for cree, they're the brightest led out there so far.
