Cleaning Throttle Body?
Old Sep 13, 2013 | 10:31 AM
Marrk's Avatar
Do we have a DIY for cleaning the throttle body?
I have a small amount of carbon on the edge of the butterfly valve (we used to call it that with carburetors). Normally, I would get to work on it with a wire brush and some carburetor cleaner, but since the Fit has fly-by-wire and a million other sensors, etc., I didn't want to start man-handling things only to have the engine throw a code later.
So, what's the proper way to clean the throttle body?
Old Sep 13, 2013 | 01:40 PM
Wanderer.'s Avatar
TB cleaner and a rag? I don't see the need for a wire brush, and I wouldn't want any bristles coming off and going in there. I just cleaned the TB on a 25 year old Explorer that I don't think has ever had it cleaned and it all came off with a rag and TB cleaner. Just put some elbow (finger?) grease into it.
Old Sep 13, 2013 | 05:34 PM
Marrk's Avatar
^^You just clean what you see? You don't attempt to open the butterfly in order to clean a little more thoroughly?
Just asking.
Old Sep 13, 2013 | 05:51 PM
Wanderer.'s Avatar
Of course, I just reach back behind the throttle plate with my fingers. I have piano fingers. I also clean the edges, front and back of the throttle plate.
Keep cleaning till the rag doesn't turn black anymore.
Old Sep 13, 2013 | 10:24 PM
CasualFitOwner's Avatar
The manual instruction says to remove the throttle body and
  • Always remove the throttle body to clean it.
  • Be careful not to pinch your fingers.
  • To avoid removing the molybdenum coating, do not clean the bearing area of the throttle shaft (A).
  • Do not spray carburetor cleaner directly on the throttle body.
  • Use Honda genuine carburetor cleaner.
Afterwards, it says to use "HDS" to reset throttle position (TP) learned value.
  • Make sure all electrical items (A/C, audio, lights, etc.) are off.
  • Reset the ECM/PCM with the HDS. (or disconnect the battery for a minute)
  • Turn the ignition switch to ON (II), and wait 2 seconds.
  • Start the engine. Hold the engine speed at 3,000 rpm (min −1 ) without load (A/T in P or N, M/T in neutral) until the radiator fan comes on, or until the engine coolant temperature reaches 90 °C (194 °F).
  • Let the engine idle for about 5 minutes with the throttle fully closed.
  • NOTE: If the radiator fan comes on, do not include its running time in the 5 minutes.
  • Verify on the HDS data list that the idle learn procedure is complete.
Old Sep 14, 2013 | 12:43 PM
Carbuff2's Avatar
Good info here, from Wanderer. and CasualFitOwner.
Important points:
I clean the TB same as Wanderer. The key statement is
And yes, you DO need use a cleaner that is safe for plastics or sensors. Most autoparts stores sell "intake cleaner" that is safe.
And yes, you WILL need to do the ILP. I forgot and my idle was weird for a couple weeks until I did it. (The car WILL re-learn on its own eventually, BUT!)
Old Sep 14, 2013 | 01:05 PM
Marrk's Avatar
Easy for you to say.
What's "HDS" and "ILP"?
Old Sep 14, 2013 | 01:25 PM
Hootie's Avatar
"Honda Diagnostic Scanner" and "Idle Learn Procedure".
Wreck Ignition
Jul 10, 2015 04:31 PM
Remould
May 29, 2012 11:39 PM
kimo
19
Oct 6, 2007 05:29 AM
alf74
Jul 25, 2006 02:30 AM
kimo
Dec 20, 2005 04:12 PM
