Question re hitch install / frame inserts
Installed a hitch on my 07 Sport.
The bolt on the driver's side (that normally mounts the skid shield) has a problem.
Does anyone know if the frame crossmember is threaded itself or if there is a welded nut of some sort inside the crossmember?
It seems like maybe it's a nut and it broken loose. I tried to loosen the bolts to align the hitch and that one won't loosen - it just spins and tension never changes.
Any ideas on how to "fix" it?
Thanks!
Thanks!
pearl
Apr 2, 2026 10:42 PM
vulcaninja
25
Feb 8, 2016 10:16 AM
Tork
Dec 11, 2008 10:40 AM
