Lighter outlet
Old Apr 6, 2015 | 04:31 PM
F-it good's Avatar
Lighter outlet
Anyone know where can I find another lighter outlet? It had stopped working and took it apart like this video on YouTube, trying to remove this burnt piece of metal but it did not have that metal. I lost a piece of the lighter outlet somewhere so...... It won't go back together. So now my only solution is, buy a new one. Anyone know where can I look?
Old Apr 6, 2015 | 10:29 PM
DrewE's Avatar
You can get replacements that are not precisely identical at pretty much anywhere that sells auto parts—auto parts stores, Amazon, probably Wal-Mart—and at marine/boat supply stores. Pick one that you like; there are different styles of covers and so forth.
You could get an exact replacement from Honda.
Do check that the fuse is not blown too when you put in the replacement. I wouldn't be surprised if that was the reason it stopped working.
Old May 4, 2015 | 08:31 AM
F-it good's Avatar
Thanks, its not the fuse but ill check around.
Old May 4, 2015 | 08:58 AM
Edison Carasio's Avatar
I had this happen on my car. You can order new lighter assemblies from the dealer for about $25 or so. I replaced the fuse, it didn't work. Then I put in a new assembly, then that blew the fuse. So I replaced the fuse again and all it good now.
cwbfan10
May 26, 2016 05:13 AM
SilverEX15
Jul 30, 2015 03:30 PM
oneder101
Jun 15, 2015 05:03 AM
fad3r
Jan 27, 2013 04:04 PM
neteng101
Oct 22, 2008 12:55 AM
