Noise at cold start.
Old Feb 24, 2019 | 09:09 PM
Jared592's Avatar
Figured my issue out. It was the idler:
Old Feb 25, 2019 | 07:34 AM
doctor J's Avatar
Thank you for update!!
Old Feb 25, 2019 | 09:07 AM
Jared592's Avatar
You got it! It drives me nuts when people don't post the resolutions to their problem threads so I try to make sure that I do.
Old Feb 25, 2019 | 12:13 PM
carotman's Avatar
What's the part number on the bearing? You could probably just change the bearing and keep the pulley.
Old Feb 25, 2019 | 03:08 PM
Jared592's Avatar
You could definitely do that if you were so inclined. Here's the part itself. You can make out the bearing part number from the picture:
Amazon Amazon
Old Feb 26, 2019 | 10:03 AM
doctor J's Avatar
I managed to press a new bearing into the idler (got bad one for free, now having spare) I used SKF bearing made in Argentina (if it makes any difference)
Old Feb 26, 2019 | 10:14 AM
carotman's Avatar
Glad to know the bearing alone is available.
I've seen some bearings not available to the individuals, only OEMS.
Old Sep 12, 2020 | 12:55 AM
KwazyKwaig's Avatar
Yes indeedy, the idler bearing is replaceable. I have a press but I'm sure you could whack it out using a proper size socket and a good size dead blow hammer or lead mallet. I don't like pressing bearings with steel hammers but it can be done. The bearing for GD Fits is size 17x40x12, industry number 6203 2RS (2RS stands for two rubber seals). I found one on Amazon for just six bucks! Honda does not sell just the bearing, they wanted $62 for new idler pulley. Takes a few minutes to press out old bearing and install new. Well worth your time. As another person posted, there are aftermarket pulleys which are wider and will bind unless you install the proper thickness washer as a spacer. Easier IMHO to just replace the bearing of original pulley and cheaper too. The pulley itself should last forever.
07FitSprt
Feb 24, 2019 09:06 PM
tyrtill
Jul 31, 2018 08:25 PM
mnapuran
Jun 11, 2016 06:00 PM
myfitfreakacct
Aug 10, 2011 01:51 PM
gabriel
May 4, 2005 11:16 AM
