Best intake manifold/intake combo
Old Mar 25, 2017 | 04:50 AM
BUCHOG92's Avatar
Hey guys,
so so I was looking to upgrade my intake manifold and intake. I was wondering if you guys help me find the best combo to have on a automatic engine. Right now I have a stock manifold with a short ram intake. What would be better combo to have if I'm looking for air flow and power? I'm looking at a either a power chamber top fuel or t1r intake. And for the manifold I was looking at the weapon r but I'm not sure if I have to tune it since I have a automatic. Is there any other intake manifold out there that I should consider?
thanks for the help!
Old Mar 28, 2017 | 03:45 PM
domoMKIV's Avatar
Probably not a worthwhile purchase unless you are going to have the car tuned for the modifications.
Old Mar 28, 2017 | 03:59 PM
This.
And either way probably not worthwhile. You're not going to gain much power regardless.
Old Mar 28, 2017 | 06:00 PM
dwtaylorpdx's Avatar
There is a HPD intake manifold that might give a bit, but its almost a unicorn horn to get ahold of one.
Old Mar 31, 2017 | 11:29 AM
cnordt24's Avatar
I have a Weapon R intake manifold paired with a Last Station chamber intake which I love so far. I was previously using an Apexi power intake which I liked, but the chamber has better response and I can feel the power through more of the band. Also, like what was mentioned above, I am also tuned with a flashpro and I'm also using a R18 Civic throttle body w/throttle body spacer which allows more air flow over stock. With a tune you will notice an increase in power, but don't expect to be racing Evos down the highway.
Old Apr 8, 2017 | 10:32 PM
Rollerboots666's Avatar
Do you have your Dyno results on FF? I'm curious to see what the car did. Thanks.
Old Apr 9, 2017 | 04:43 PM
cnordt24's Avatar
Not as of yet, there is a dyno day coming up near me in a few weeks that i should be able to make it to. Then I'll know for sure, I'm very curious myself.
Old Apr 10, 2017 | 12:45 AM
Truly will be interesting to compare the power and torque curves to a stock setup,
I'm bettng the aftermarket has higher peak power and torque but gives it away at midrange/lower rpm's
Old Jun 29, 2020 | 08:11 PM
Eliseo Cortes's Avatar
intake
If you want to increase power, i suggest high compression pistons ( 12:1:1) or (13:1:1)
Buy a used intake manifold, open it, port inside, then epoxy it, fuel pressure regulator, and then get a good ecu reflash....
Old Feb 6, 2021 | 12:58 PM
Ryan Hendrickson's Avatar
What did you do with the EGR valve?
Thanks
valhalla
Jul 15, 2012 10:13 PM
valhalla
Jul 5, 2012 07:57 AM
alf74
Jul 24, 2008 01:30 PM
kimo
Mar 8, 2007 11:41 AM
tonyrace_41
Jun 21, 2006 09:55 AM
