weird electrical issues
Old Jun 21, 2017 | 09:28 PM
willy65000's Avatar
I could use some help with some recent electrical issues. there is a circuit that has the tail lights and the hvac back lighting on it and that fuse keeps blowing. It happens as soon as i turn the ac on. makes no sense since the ac and the tail lights on on separate circuits. also, when i turn the headlights on the drivers door lock actuator makes a clicking noise but doesn't actually lock or unlock the doors while making the noise. and lastly the instrument lights and radio go blank when the headlight are turned on. is there a component or module that is tied to all of these things that could be failing? Is there a way to test that component? Any help with this would be greatly appreciated. This is a car that runs well but has high miles and isn't worth putting the money into having the dealer diagnose the problem.
Old Jun 21, 2017 | 11:07 PM
idrivemyself's Avatar
How much more of a visual and hands-on inspection have you done thus far? Have you inspected and cleaned all of the ground circuits? Or inspected the backside of the fuse block? Done any pull tests? Start simple and work from there. Thoroughly going through the chassis may present the issue, sometimes that's all it takes and can save you hours of chasing wires and modules with a DVOM. Let us know if you're still stuck after that and we can run through the wiring diagram. Good luck
DrewE's Avatar
I can think of two possibilities.
First, poor grounds can cause all sorts of weird electrical issues. It's not uncommon on the Fit, I gather, for the main battery ground connection to the frame to get less than solid with corrosion etc. over time, which could possibly cause at least some of these symptoms.
Second, maybe there have been mice or other critters chewing on the wire harnesses somewhere, and there are (possibly intermittent) shorts.
Old Jun 22, 2017 | 07:45 AM
willy65000's Avatar
Thanks for the replies. I should have mentioned that I've already had a mechanic from an independent shop spend a couple of hours on trying to diagnose this problem and he thinks it could potentially be the gage cluster, the fuse box and found no bad grounds or fried wires.
Old Jun 23, 2017 | 11:38 AM
JockoT's Avatar
I had a similar problem with my Volvo. It was an intermittent short where the wiring flexed as the boot/trunk lid opened and closed.
Old Jun 24, 2017 | 12:32 PM
willy65000's Avatar
the guy that looked at the car checked all of the grounds and wires that are accessible. after digging into this more online and talking with a very helpful Honda dealer parts guy He thinks that based on my symptoms I need to look at the possibility of it being the multiplex controller. It's the computer that's integrated into the interior fuse box. He's never heard of one going bad on a fit but they do go bad on other Honda's. Has anyone on this site had to replace one?
Old Apr 17, 2021 | 07:28 PM
nature boy's Avatar
what was your resolution ? I have having similar issue and mechanic says interior fuse box bad. I am not finding the part online.
Fit4beach
Nov 17, 2021 08:03 PM
rohanks
Oct 11, 2013 02:43 PM
setter11
Jan 23, 2011 12:29 AM
omfgitshimm
Oct 27, 2009 11:58 PM
kyo2529
Oct 3, 2007 02:15 PM
