A hairline crack may cause spark plug to came loose
Old Dec 19, 2017 | 11:25 AM
doctor J's Avatar
in 07 Fit engine the spark plug hole is located at the junction point of the individual exhaust ports (right between 2 exhaust valves). I would not be surprised if detailed examination will find a hairline crack between exhaust port and the spark plug threaded hole. If such crack is present , the plug will be coming loose over the time.
Old Dec 20, 2017 | 10:00 AM
GAFIT's Avatar
Interesting thought!
Our #3 loosens over time. I've blamed it on improper pitch angle of the threads or not tight enough tolerances of the threads, but your idea could be true.
Of note also though is that the plugs our motors call for have much less total threads than any of my other late model vehicles with COP design. Ecoboost motors plugs have literally 50% or more threads on the plugs.
Old Jan 21, 2019 | 12:12 AM
dwtaylorpdx's Avatar
Loose plugs have been a AL head issue for years,, not just honda,, Miata's MR2's , heck my 69 VW bug spit them out..
You cant EVER over torque one,, once you do the threads get torqued out of shape and they never stay tight again.
All I've ever done is cleaned the threads in the head with a nylon gun brush and a gun swab with carb cleaner on it.
Put the plugs in dry and since I change them about every 20 to 30 K miles, never had a problem.
Old Jan 22, 2019 | 11:45 PM
GAFIT's Avatar
That doesn't explain how my friends GE blew the OEM, never changed, plug out of the head. I seriously doubt it was over torqued at the factory.
Triskelion
Sep 23, 2022 02:58 AM
Kevin Evans
Sep 26, 2020 02:05 PM
Bryanfit
19
Mar 17, 2017 02:03 PM
doctor J
Aug 26, 2016 03:33 AM
wackyflik
Oct 4, 2014 09:11 AM
