Power Enterprise Co., Ltd. supercharged Honda GE8 FIT
Full bolt-FULL KIT for car inspection! Only 5k -Bargain :rotfl:
新型FIT スーパーチャージャーキット ROTREX Up 30% occurrence catalog value MAX156ps to torque up the entire powerful acceleration is extended to high rotation smooth. I made it easy mounting of the number of parts is small. Mapping optimization using P-MAP (data entered) and large capacity injector that comes with fuel and ignition control, use the air impulse Ⅱ, I realized a reduction of the intake resistance. Full warranty of 50,000 km or two years in the supercharger body maintenance of super charger only oil exchange filter replacement time exchange ※ oil: 50,000 km or 2 years http://power-enterprise.co.jp/rotrex...x/gefitegl.jpg http://power-enterprise.co.jp/rotrex...ex/gefitgl.jpg Specification POWER (ps) TORQUE (kgm) Normal 120ps/6600rpm 14.8kgm/4800rpm ROTREX 156ps/6600rpm 17.8kgm/4800rpm http://power-enterprise.co.jp/rotrex...trex/gekit.jpg Charger body Large capacity injector Pulley Air impulse Ⅱ ROTREX for oil Various S / C bracket P-MAP (installed) V-belt Oil cooler Oil reserve tank Piping Silicone hose Oil hoses Oil line ROTREX oil filter Others: bolt nut color clip nipple adapter various stays, various bracket, hose band, etc. Guaranteed for two years or 50,000 kilometers to the charger body Notes ■ This product is only GE8 KIT. Separate air compressor conformable confirmation thank you to confirm. (Depending on model year.) For GE9 (4WD キ 5AT), please contact us for mounting unconfirmed. ■ Use the high-octane gasoline always. ■ Please use the thing of the heat value of the number 7 or more plug. ■ The engine oil should be used for the turbo (10W40/15W50) has been the fuel adjustment confirmation in ■ our air impulse Ⅱ. |
First photo shows this on a JDM car...
Just like the "Turbo Kit" I found from CX Racing a while ago I HIGHLY doubt this will be a "bolt on" for a US Spec GE... |
Just by looking at the picture 75% sure that intake piping wouldn't clear the brake booster on USDM Fit :confused:
Linear 153hp still notbadobama.jpg I love the engrish :rotfl: |
I dont see enough benefit for the money, if $5k is accurate
That turbine is tiny! and recommending 10w40 inplace of 0w20 doesnt sound right at all |
More info please
