Cheap(er) sri that's actually worth the money
Just got my 09 fit, I know theres a ton of info in the search option, but it seems its always a different year, with a different car, with different mods.. so thats why im asking here. Im not looking for performance upgrades on a 117 hp car, I just want it to look clean under the hood. atm my battery is at an angle, and the stock airbox is pretty bulky.. I dont want any codes popping up, so I will pay the premium for having my 51r battery be straight in the tray, to possibly gain a few hp and mpg...
suggestions are open |
PRM or K&N will give you plenty of room in the bay. They both cost about the same, $240 or so. You could also DIY one, but IMO doesn't look as nice. There's DIY intake threads on here everywhere if you want to go that route, just search for it.
Originally Posted by Desmond Lamar MacRae
(Post 1229040)
Or get the Takeda CAI for 208.99
Cold Air Intake System Takeda Takeda Stage-2 PRO DRY S Intake System; Honda Fit 09-13 L4-1.5L (pol) TA-1003P - aFe Power http://afepower.com/catalog/TA-1003P/TA-1003P_400.jpg |
(Post 1229031)
and as far as the DIY intakes go, has there been one proven to NOT throw a code? Maybe I havent searched enough, but all the recent ones ive seen throw a code |
Lots of good reviews on both of those intakes, I just run the stock box with panel filter because I don't think $250 for an intake is a good investment for me... none of them make much power over stock and I don't like that much noise. However, I can understand wanting to have a little more room in the bay with the 51R. I like the little heat shield K&N gives you, the ducting on the hood flows into that box from what I can tell so that's kind of cool.
DIY intake shouldn't throw a code if you build it right, there's really not much to it on these cars they're so short. Just keep the MAF location as close to the stock location as possible and you should be fine i'd think. Here's a really good thread on intakes from a while back when people actually talked about technical stuff on here :rotfl: https://www.fitfreak.net/forums/2nd-...vs-prm-vs.html Some of the pics are broken but the discussion is still relevant. |
Originally Posted by comatoast
(Post 1229049)
I would like a short ram, as the minnesota winters can really gum up a cai.. been there done that :/ So of those two is there a better one?
and as far as the DIY intakes go, has there been one proven to NOT throw a code? Maybe I havent searched enough, but all the recent ones ive seen throw a code https://www.fitfreak.net/forums/2nd-...e-cai-sri.html Don't expect any real power gains from any intake though because the engine computer is going to just dial out any gains you get. It does make the Fit sound more like a sports/race car when you get on it though. Driving around normally and on the highway it sounds basically identical to the stock airbox setup, so it's not annoying at all. -Dustin |
Originally Posted by Bama3Dr
(Post 1229081)
:popc: :rotfl: |
There was one on one of the FB groups the other day. HPS or something like that? Under $200 and tucks neatly in the back of the engine bay.
The ecu will not just dial out gains. Extra air means it will use extra fuel. The ecu will maintain AFRs.
I spent $15 on a 2.5inch coupler and 2.5inch filter on ebay. cut teh factory topbox that has the MAF tube, and boom, you have a short ram intake that puts the filter right where the airscoop under the hood directs it to. going to colder spark plugs and using 91 or 93 octane fuel will give you more benefit |
| All times are GMT -4. The time now is 05:35 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
