2nd Gen GE8 Specific Fit Exterior Modifications & JDM Styling Sub-Forum Threads discussing exterior modifications and JDM styling for the 2nd Gen GE8 Honda Fit
my ge looks like hitler o.O
Old Dec 17, 2010 | 04:05 PM
phuccer's Avatar
The front license plate looks like it sits too high up for me. The license plate looks like hitlers mustache.
I tried to flip it around today, but the stock bolts are too short.
Has anyone done this? Did you just have to buy longer bolts, or did you have to buy a license plate relocation hit?
Old Dec 18, 2010 | 12:57 AM
Mr.Bubbles's Avatar
I made a custom bracket using a 12" mending brace. It made it sit lower and offset. But then i just plugged up the hole and put my plate inside against my windshield so the front is clean
Old Dec 18, 2010 | 04:32 AM
john21031's Avatar
mine looks like albert einstein's mustache.
Old Dec 18, 2010 | 12:11 PM
phuccer's Avatar
yeah, i would do that too, but im from los angeles california...it wont take long for a cop to pull me over for it =[
Old Dec 18, 2010 | 02:58 PM
Java^FiT's Avatar
Yeah you just need longer bolts to do this. after you install it this way it sits kind of angled so if you want to add some rake to it just sand down both bolt points together to the desired rake.
Old Dec 18, 2010 | 03:25 PM
jeff_1986's Avatar
I got a base Fit (LX) but I'll show ya my plate relocation anyways.. it's homemade but turned out pretty good:
Old Dec 18, 2010 | 06:04 PM
phuccer's Avatar
that looks good, how did you do that?
Old Sep 2, 2012 | 01:07 PM
j.estrizzle's Avatar
The idiot dealer just drilled into the bumper and screwed the plate to the bumper. He did not even look in the tire area for the plate frame.
I relocated my plate to the side. i have a GE sport. I used the stock frame. I made a template for the holes. I used those plastic things that you use to hold your toilet paper holder to the wall. they expand four ways when you screw in a screw. looks good and is sturdy.
Old Sep 2, 2012 | 01:32 PM
DaveFL's Avatar
Special bracket bolts to the underside of bumper, you could have mine if you were closer, removed as it only had dealer name ad plate. While I was at it also removed the rear frame and cleaned off the advertising dealer had on it. Didn't like the dealer and wasn't about to give him free advertising space.
dancingsun
67
Jan 19, 2015 05:55 PM
BayAreaKid
Jan 18, 2015 10:33 PM
Mike Houser
Aug 9, 2014 05:52 PM
BlueCell
Texas Community
Feb 21, 2008 11:33 PM
sosoqtpinoy
20
Feb 1, 2008 10:44 PM
