2nd Gen GE8 Specific Fit Exterior Modifications & JDM Styling Sub-Forum Threads discussing exterior modifications and JDM styling for the 2nd Gen GE8 Honda Fit
cover for back above bumper ??
Old Jul 27, 2014 | 07:39 AM
mg10461's Avatar
The back part of my 2009 sport fit is getting beaten up - putting bikes in and out, sitting on it etc. I think i have seem rubber looking protectors that go there, but I can't remember for the life of me what they are called. Anyone have any recommendations? I have a picture of the part I am would like to be covered.
Thanks all !
Old Jul 27, 2014 | 08:06 AM
n9cv's Avatar
I bought some 6" wide traction tape that you would use on stairs. I got it in a roll from TSC for $5.00 or $6.00. Then I trimmed it to match the curve of the bumper and stuck it on. It works very well.
Old Jul 27, 2014 | 08:07 AM
mg10461's Avatar
That is a super idea!
What is TSC and what did you stick it on with please?
Old Jul 27, 2014 | 10:34 AM
sooznd's Avatar
The one Honda sells is basically traction tape cut to fit the bumper-- I have a small tear in mine from moving bikes, furniture, etc. in and out. I also got another one which is a bit heavier--though still not as good as the heavy duty rubber ones you see on Subarus and other SUV's
Rear Bumper Protector for 2007 - 2014 Honda Fit
Old Jul 28, 2014 | 03:33 AM
n9cv's Avatar
Sorry, TSC is Tractor Supply Co.
For Life Out Here | Tractor Supply Co.
I do not if they are nationwide or not. Obviously their customers are not big city folks. Their customers are suburbanites and country people.
I have also seen this stuff on a roll at Ace hardware. You can buy 3 feet or so and that is all you should need. It is self adhesive. Just trim it to fit, pull the backing paper, and stick it on . I suggest that the bumper be clean of dirt, wax, etc. I would wipe it down, probably with alcohol, before installing. I have seen it in gray and black with a sandpaper type finish and a rough non-sandpaper finish. I understan they also make white and clear. I just used some off of a roll that I had around here.
Here is some 6" wide on a 30 feet roll. This one is the gritty (sandpaper) type. It also comes in 1, 2, and 4 inch widths.
http://www.ebay.com/itm/6-x-30-Black-Roll-Safety-Non-Skid-Tape-Anti-Slip-Tape-Sticker-Grip-Safe-Grit/271532405212?_trksid=p2047675.c100010.m2109&_trkparms=aid%3D555012%26algo%3DPW.MBE%26ao%3D1%26asc%3D20131231084308%26meid%3D8628280060731251003%26pid%3D100010%26prg%3D20131231084308%26rk%3D1%26rkt%3D24%26sd%3D281358194022
Old Jul 28, 2014 | 01:40 PM
going back to the original question, those things are called bumper "applique."
Old Jul 28, 2014 | 03:18 PM
mg10461's Avatar
Thanks ! This is such a nice and helpful forum community !
Old Jul 28, 2014 | 03:56 PM
timemachine's Avatar
https://flic.kr/p/ob2vJv
Thats the rear of my car
Old Jul 28, 2014 | 04:18 PM
dpmason's Avatar
That looks great timemachine, I was thinking of ordering the OEM strip on Amazon but it looks like the traction tape works just fine.
Was it at all tricky to put on? There are several comments on Amazon from DIYers that got bubbles or had trouble getting it exactly straight.
Old Jul 28, 2014 | 04:26 PM
Thanks Dpmason. The dealer put it on for me.
I use to work at a graphics shop and the trick to aligning is you tape down the Applique with masking tape and adjust it to where you want (before removing the backer) . Once you are satisfied you tape it even more to secure it down. Then you lift one side of the applique and remove about 2 inches off the backer and cut the backer off. Then you tape it to the car and from the bottom you unroll the backer and it will give you a perfect application.
Old Jul 28, 2014 | 05:57 PM
dpmason's Avatar
Nice tip timemachine, I think I will try it!
Old Jul 29, 2014 | 01:52 PM
-jacob-'s Avatar
Yep... def wll try it also
BigSpark
Dec 3, 2018 05:34 PM
Akiod
Aug 8, 2016 11:15 PM
BonesPeace
Jun 28, 2016 01:04 PM
jthomasolsen
Nov 9, 2015 09:36 PM
07HondaFit
Aug 12, 2015 11:15 AM
