Denso 156700-2680 relay
Old Jul 7, 2019 | 09:27 AM
Herut's Avatar
Can anyone tell me what the 4 pin Denso blue 156700-2680 relay is for? It is in an under-hood box next to a grey 5 pin mitsuba rc-5102. Thanks.
Old Jul 7, 2019 | 11:02 AM
2012FitFan's Avatar
According to this post on a European based forum, it’s the A/C clutch relay? This is referring to a Civic.
https://www.civinfo.com/forum/honda-...lay-check.html
This reddit post mentions the Denso part number you posted and someone replied that Acura updated the part number, which is the A/C clutch relay part number you see around here. This is referring to an Acura.
https://www.reddit.com/r/autorepair/...7002680_denso/
Hope this helps a bit. Maybe someone else will reply with better knowledge.
Old Jul 7, 2019 | 05:59 PM
Herut's Avatar
Thank you 2012fitfan. My bad: the blue denso was actually marked 156700-2780 (not 2680...) I guess I looked up so many Denso numbers, I got confused. Do you think the A05 is still a swap for the 2780 Denso as well? I couldn't find what the difference between -2680 and -2780 might be.
Panthese
33
Aug 18, 2020 12:08 PM
omygod711
Dec 28, 2018 02:56 PM
seattleguy
Jun 19, 2018 07:00 PM
savemyjazz
Mar 19, 2015 11:08 PM
egvtec
Jan 20, 2013 11:12 AM
