Water pump leaking after engine replacement.
Old Feb 1, 2020 | 09:24 PM
dlogvine's Avatar
When putting an old water pump on the replacement engine, I checked the gasket and it looked good, no reaps or tears, the rubber was not hardened. So I used the old gasket, but the water pump is leaking now. I'll check the bolts, might have forgotten to tighten them up or possibly the gasket is of threinstall the pump.e groove. Either way, this time will buy a new gasket and reinstall the pump. As a rule, should I use a new gasket every time I take off the water pump?
Old Feb 2, 2020 | 07:00 PM
woof's Avatar
Always always always put a new gasket on pretty much anything you've disassembled when putting it back together again.
FitCrazy80
Feb 27, 2013 03:23 PM
robcollins5
Mar 11, 2010 01:27 AM
coralaholic
Sep 18, 2009 11:37 PM
pcs0snq
Apr 15, 2008 12:51 AM
mmdir2005@yahoo.com
Oct 11, 2005 11:36 PM
