Accessory wire hookup color
Old Jan 10, 2021 | 03:27 PM
Zardiw's Avatar
Trying to find the accessory wire by the fuse box......not having much luck.
Anybody know the color/location of ACC hookup?
OK.....solved.......need a piggy back fuse, and use a meter/test light to find a fuse that's on when the key is on accessory.
Each fuse has a metal dots on it where you can test if there's current or not.
Then you replace that fuse with a Piggy Back Fuse and voila you have a place to hook up an accessory.
You want to get some spare fuses in case you blow that fuse.....
Link to a nice set:
Amazon Amazon
Check this video for details:
z
Old Feb 5, 2021 | 05:16 PM
winkybil's Avatar
My question is actually about is it required to have the red cable hook up to the positive terminal and vice versa with the black cable when jumping a car? Will anything bad if I connect the cables the opposite way.
Kodi nox
Old Feb 15, 2021 | 10:05 AM
Zardiw's Avatar
No. Not if you want a nice Fireworks Display.......lol.........
z
rjm161
Jul 5, 2018 02:45 PM
elsabaw
Jun 22, 2017 10:26 AM
Enzo3856
2nd Generation GE8 Specific Fit I.C.E. Sub-Forum
Sep 17, 2015 04:16 PM
noripwr
Oct 21, 2014 06:48 PM
