Crank no-start (no power at fuel pump unless I jump the relay)
Old Aug 22, 2023 | 11:39 AM
Timo_T's Avatar
So I'm trying to help out a friend with her 17 year old sons 2010 Fit. Basically it was just running/driving fine, they went on vacation so the car was parked for a week and now it cranks but doesn't start. First thing I notice was I couldn't hear the fuel pump prime, checked the fuel pump fuse it's good with power going through it. Next for $20 we ordered a fuel pump relay from Amazon still no power at the pump.
Not sure how accurate this Denso wiring diagram is ( the 2 relays I have don't have any markings) but with the key on I get power at pin #4 and with the pump fuse removed power goes away so I'm guessing that's actually battery + pin
I do get power to the pump when I jump pins 3 & 4 on the relay (Also I can hear the pump when relay is jumped, so good wiring and a a good pump)
Pin #1 I get power to with the key on using a test light
So I get something to all the pins except pin # 2
Along my Googling people have pointed to the PCM or the immobilizer, as far as the immobilizer when I put the key in and in the on position I don't see any icon with a key not even for a split second.
Any thing else that's common with these? or that I should check? I think it's probably going to end up at the dealership.
Thanks in advance.
Old Aug 23, 2023 | 09:29 AM
Timo_T's Avatar
Turns out I do not have a good ground for the fuel pump relay in the fuse box. Anyone know where that ground is at?
Old Aug 24, 2023 | 05:14 PM
Alexander Chernoch's Avatar
Do you have the manuals for the Fit? If not, here is my google drive link: https://drive.google.com/file/d/1eZw...usp=drive_link
It looks like Volume 1 page 11-276 is where you might be able to find your answer or at least a start.
Old Aug 24, 2023 | 05:37 PM
Better yet these images may help!
From Fuel pump to relay.
from relay to other systems.
Old Aug 25, 2023 | 03:50 PM
Timo_T's Avatar
Awesome thanks!!
Old Aug 25, 2023 | 05:03 PM
Timo_T's Avatar
Do you happen to know where that PGM-F1 Main realay(s) are located? I'm assuming they are internal and part of some other module?
Old Aug 26, 2023 | 01:54 PM
It should be driver side underdash
Old Aug 26, 2023 | 01:56 PM
Old Sep 8, 2023 | 12:06 PM
Timo_T's Avatar
***UPDATE****
Well the car ended up at the Honda dealership and they said the ECU is bad and we were quoted $2,300 to fix (we only paid 1500 for the car 3 years ago) They said if we found our own ECU they would program it for $350. off to eBay...
RandomB
Apr 28, 2021 06:06 PM
seattleguy
Jun 19, 2018 07:00 PM
jaebee
Jun 11, 2009 08:53 PM
DOHCtor
Feb 14, 2009 03:56 PM
