Hatch actuator repair advice
Old Sep 23, 2023 | 03:28 PM
bobus1964's Avatar
My mother has a 2014 Honda Fit which I have found is apparently the black sheep in the line .
She needs to replace the actuator in the rear hatch but the dealership is quoting 300+ for the part. No cars in the auto salvage to get one off of.
Any other hacks to get it fixed?
Thanks
Old Sep 23, 2023 | 09:18 PM
Drew21's Avatar
If you haven't already done it, I would start by pulling out the actuator to determine if something is visibly wrong. Maybe it's just stuck with rust or dirt. Maybe something got jammed in the mechanism. Maybe the electrical connection popped loose.
It's easy to remove the plastic interior of the rear hatch and once you get that off you should have access to both the inner and outer portions of the actuator.
I follow the K.I.S.S. model. If something is supposed to cost hundreds/thousands of dollars to fix, it's worth 30 minutes of my time to confirm that there is really a serious problem that I can't fix myself.
Old Sep 24, 2023 | 03:03 AM
JDFit's Avatar
Thanks
I'm not sure what you mean by actuator but if you are talking about the Liftgate handle not working, I followed this video to remove mine. I just cleaned it and lubed it, then replaced it. It is working like new. But, if that didn't work, I would have bought a new part.
JDFit
Mar 14, 2023 06:29 AM
aelk799
Aug 17, 2022 06:32 PM
SilverEX15
Dec 4, 2021 07:30 PM
GRF
Oct 17, 2021 11:12 AM
BMCBoid
Mar 5, 2016 10:25 AM
