Fit GE UK owners - Rear Foglight?
Old Feb 7, 2024 | 04:31 PM
USE20's Avatar
Hi all
I have seen quite a few GE Fit's being imported to the UK, mine will arrive sometime soon, which has me thinking about how to install the rear foglight. I don't know if there is any wiring in placefrom the factory or similar to make this more straightforward.
Does anyone know the simplest way to do this?
Thanks
Old Feb 7, 2024 | 07:02 PM
NWCH's Avatar
Got a picture?
Old Feb 8, 2024 | 04:10 AM
USE20's Avatar
Hi, no pictures I'm afraid as the car is still on a boat. Essentially I am wondering how others have put a rear foglight in a JDM Fit GE.
Thanks
Old Feb 8, 2024 | 08:55 AM
NWCH's Avatar
Yes the do make rear fog light taillights. But they won't be cheap.
https://www.fitfreak.net/forums/fit-...ge8-sport.html
Old Feb 14, 2024 | 03:12 AM
USE20's Avatar
Thanks all, not quite the information I was looking for but appreciated. WIll sound it out when I get the car.
Old Feb 22, 2024 | 06:14 PM
Dave74's Avatar
Thanks
Normally the easiest way is to replace the right hand side reverse light bulb with a red tinted bulb and wire to that…You’ll also need a separate switch with a tell-tale light. To indicate that the fogs are on. This should be enough to get an MOT pass. This assumes the JDM GE has conventional bulbs for the reverse light? If not then you may have to switch to UK taillights. The JDM GE is old enough now that you don’t need latching relays and stuff which you would do on a newer vehicle I believe. HTH
Old Feb 24, 2024 | 05:25 AM
USE20's Avatar
Thanks Dave for the reply. After some careful ebay spotting, I managed to pick up a set of UK lights for a decent price. I was shocked at how expensive the post 2011 units are.... but then I am a tight git. It wasn't a tough decision, as personally, I much prefer the red lights over the clear ones that come on the RS.
There looks to be loads of switches on ebay that will work, without a relay apparently. I will aim for an led bulb for the foglight to lower the draw on the wire. Any idea of how many GE RS's there are in the UK? There seem to be mostly auto's for whatever reason. Insurance is going to be fun...
Old Feb 24, 2024 | 08:24 AM
Dave74's Avatar
no worries Ive been through the import process myself before so I know what its like. Ebay switch will be fine they deffo sell cheap ones which will “fit” in the fuse cover/switch panel and generally on GE8s there will at least one spare slot. Good luck 🫡
Old Feb 27, 2024 | 06:09 PM
Aljf69's Avatar
Hi, were you able to install a fog light option ? I will be carrying out that myself in the coming weeks , i was thinking of the reverse light bulb option if its normal bulbs as spoken off by dave74
jacoblong09
Jun 7, 2021 04:18 PM
ikutoisahobo
Jun 2, 2021 02:18 AM
hanzo
Oct 3, 2009 01:55 AM
dsdandaman
Aug 27, 2009 12:49 AM
sebring168
Apr 24, 2009 10:53 AM
