2012 Fit Electrical Smell
Old Jun 10, 2024 | 03:58 PM
mahplane's Avatar
2012 Fit 100k Auto Transmission my daughter started it and it had a strong electrical smell, no codes was running fine
she turned off the A/C and it kinda went away lasted about 30 minutes and went away. Anyone have any idea what it could be? Any help is appreciated
Old Jun 10, 2024 | 04:40 PM
56chevydan's Avatar
Need more info:
How long has she had the car- know the history of it?
Any work been done to the car recently?
Can you further describe what you mean by strong electrical smell? Something hot or something burning/ smoke?
Is the smell strongest inside the car or outside the car when you open the hood?
Is the car in an area where varmints can nest and/ or chew on the wiring?
Old Jun 10, 2024 | 08:05 PM
mahplane's Avatar
Opened the hood smelled nothing, we have had it for 4 yrs just inside smell lasted about 30 min Yes squirrels can get into it I guess just didn't see any evidence of it plus the car runs fine
Old Jul 28, 2024 | 03:23 AM
RussianIcedTea's Avatar
Probably just build up of different dirt, dust and grime in the ac vents. It's possible the blower fan for the AC unit has worn out the brushes on the motor and is causing the smell, but i took an original one off of a 250,000 mile fit in California where AC is used 24/7 and it was less than halfway worn through the brushes. Just get a can of kool-it ac cleaner and put it through the ac drain (plenty of videos online on how to do it) and clean the vents too and the smell will most likely go away. Otherwise it's probably something aftermarket or added to the car, most of the wiring and electrical is done pretty well on the fit and they rarely have any electrical issues. Good luck, and reply if anything changes or doesn't.
Old Jul 30, 2024 | 06:20 PM
SiXiam's Avatar
I recently noticed the switch/knob for my fan is getting hot. I got a new blower fan coming this week. So that might be a quick test if the knob feels hot when running then the blower is using too many amps and should be replaced.
DiamondStarMonsters
Aug 10, 2012 01:50 PM
Odie
May 14, 2012 11:33 AM
RubyQQ1211
California - Bay Area Community
Feb 1, 2012 03:53 PM
Scala
Jan 10, 2012 05:46 PM
