GE8: Grok 3 AI helps with Ktuner!?
Old Mar 28, 2025 | 11:19 AM
yovtecjustkickedin's Avatar
Step 1: Setup and Baseline (1–2 Hours)
Goal: Get comfortable with KTuner and establish a starting point.
Actions:
1. Install KTuner Software: Download the latest version from KTuner’s site (as of March 27, 2025) and connect your V2 or V1.2 to your laptop and OBD-II port.
2. Backup Stock ECU Map: In KTuner, go to “File” > “Save As” to save your factory tune. This is your safety net.
3. Flash a Basemap: Load KTuner’s pre-made basemap for the 09-13 Fit with SRI (under “Tunes” or “Quick Maps”). Pick the 87-octane option if available—expect ~5–10 WHP over stock (~105–110 WHP).
4. Log a Baseline Run: Drive normally (idle, cruise, WOT to ~6,000 RPM on a safe road). In KTuner, use “Live Data” or “Datalogging” to record:
1. AFR (target vs. actual)
2. Ignition Timing (degrees BTDC)
3. Knock Count (should be 0–1)
4. MAP (manifold pressure)
Save this log as “Baseline_87.”
What to Check:
· Idle AFR ~14.7:1, WOT AFR ~13:1–13.5:1 (SRI leans it slightly).
· Timing at WOT ~20–25° BTDC.
· No knock (>1 is a red flag).
Time: ~1–2 hours.
Result: Running a safe basemap, familiar with logging.
Step 2: Adjust VTEC Engagement (1–2 Hours)
Goal: Optimize mid-range torque with your SRI.
Why First: VTEC is a single-value tweak, easy to test, and impactful with 87 octane.
Actions:
1. Lower VTEC Point: In KTuner’s “VTEC” tab, find “VTEC Switch Point” (stock ~5,000 RPM). Set it to 4,300 RPM—SRI boosts airflow ~3,000–5,000 RPM, and 87 octane limits top-end gains.
2. Test Drive: Accelerate from 3,000 RPM to 6,000 RPM in 3rd gear (safe road). Feel for a smoother torque curve—stock 5,000 RPM is too late with SRI.
3. Log Data: Record AFR, Timing, and Knock at 4,000–5,000 RPM. Save as “VTEC_4300_87.”
4. Fine-Tune (Optional): If it feels boggy, try 4,400 RPM; if too early, try 4,200 RPM. Log each change.
What to Check:
· Torque dip minimized ~4,000–4,500 RPM.
· AFR ~13:1–13.5:1 near VTEC switch (no lean >14:1).
· Knock still 0–1.
Time: ~1–2 hours.
Result: Better mid-range pull (~2–3 WHP), no timing/AFR tweaks yet.
Step 3: Tweak Idle and Cruising Fuel (2–3 Hours)
Goal: Stabilize AFR for smoothness and efficiency.
Why: SRI leans out stock AFR slightly—fix low-RPM and part-throttle first.
Actions:
1. Idle Fuel Trim (~600–1,500 RPM):
o In “Fuel” tab, find low-load/low-RPM cells (0–20% throttle, 600–2,000 RPM).
o Baseline log might show ~15:1 AFR (lean). Add ~2–3% fuel to target ~14.7:1.
o Test: Idle for 2–3 minutes, blip throttle to 1,500 RPM. Should feel smooth.
2. Cruising Fuel Trim (~1,500–3,500 RPM):
o In “Fuel” tab, mid-load/mid-RPM cells (20–60% throttle, 2,000–4,000 RPM).
o If log shows >14.7:1, add ~1–2% fuel (~14.5:1 max—don’t hurt MPG).
o Test: Cruise at 2,500 RPM in 4th gear.
3. Log Data: Record AFR and Knock at idle/cruise. Save as “Fuel_Low_87.”
What to Check:
· Idle AFR ~14.7:1, no stumbles.
· Cruising AFR ~14.5:1–14.7:1, steady throttle.
· Knock 0–1.
Time: ~2–3 hours.
Result: Smoother daily driving, SRI compensated.
Step 4: Advance Timing Slightly (23 Hours)
Goal: Add a touch of power safely on 87 octane.
Why: Timing boosts torque, but 87 limits advance—IK22s help.
Actions:
1. Cruising Timing (~1,500–3,500 RPM):
o In “Ignition” tab, mid-load/mid-RPM cells (20–60% throttle, 2,000–4,000 RPM).
o Stock ~15–20° BTDC. Add ~0.5–1° (~16–21°).
o Test: Light acceleration in 3rd gear.
2. Mid-Range Timing (~3,000–5,000 RPM):
o Higher-load/mid-RPM cells (50–80% throttle, 3,000–5,000 RPM).
o Stock ~20–25°. Add ~1–2° (~21–27°).
o Test: 3rd gear pull from 3,000 RPM.
3. Log Data: Record Timing, AFR, and Knock. Save as “Timing_Mid_87.”
What to Check:
· Knock stays 0–1 (if >1, reduce ~1°).
· AFR supports timing (~13.5:1 mid-range).
· Slight torque bump felt.
Time: ~2–3 hours.
Result: ~3–5 WHP gain, still knock-free.
Step 5: Tune WOT Fuel and Timing (3–4 Hours)
Goal: Maximize power at high RPM.
Why: WOT is where gains shine—87 octane caps timing, so fuel is key.
Actions:
1. WOT Fuel (~5,000–6,800 RPM):
o In “Fuel” tab, high-load/high-RPM cells (80–100% throttle, 5,000–6,800 RPM).
o Baseline ~13:1–13.5:1. Add ~5–7% fuel to hit ~12.5:1–12.8:1 (safe power).
o Test: WOT in 3rd gear to 6,500 RPM (safe road).
2. WOT Timing (~5,000–6,800 RPM):
o In “Ignition” tab, same cells. Stock ~20–25°. Add ~1–3° (~21–28° max).
o Test: Same WOT pull.
3. Log Data: Record AFR, Timing, Knock. Save as “WOT_87.”
4. Adjust: If knock >1, reduce timing ~1°; if AFR >13:1, add ~2% fuel.
What to Check:
· AFR ~12.5:1–12.8:1 WOT.
· Timing ~27–28° max, knock 0–1.
· Power feels stronger ~5,000–6,500 RPM.
Time: ~3–4 hours.
Result: ~5–10 WHP gain, ~115–125 WHP total.
Step 6: Polish and Finalize (2–3 Hours)
Goal: Refine and add drivability tweaks.
Actions:
1. Throttle Response: In “Throttle” tab, increase “DBW Sensitivity” ~10–15% across 600–6,800 RPM. Test tip-in and WOT feel.
2. Rev Limiter: In “Rev Limiter” tab, raise from 6,800 RPM to 7,000 RPM (safe with IK22s). Test briefly.
3. Final Log: Full drive (idle, cruise, WOT). Save as “Final_87.”
4. Review: Ensure AFR ~14.7:1 idle/cruise, ~12.5:1 WOT; Timing ~27–28° WOT max; Knock 0–1 everywhere.
Is this helpful or a Dangerous Pipe Dream?
Yo
Old Mar 28, 2025 | 02:40 PM
Drew21's Avatar
I would rather speak to a rational human being who has experience with Ktuner (or getting more HP as in your other post) rather than trust what is essentially an Internet-wide vacuum cleaner sucking up everything (good and bad, true and false) and attempting to summarize it without any sense of what any of this actually means.
Old Mar 28, 2025 | 10:55 PM
Best practice with these llm is to not use them for stuff requiring any level of expertise unless you have the expertise to make sure it doesn’t make up anything harmful (which is common).
at which point the llm isn’t saving time or effort anyway
I understand you’re excited about this stuff but you really need to slow down and do some research/homework yourself.
Old Mar 29, 2025 | 12:14 AM
Thanks for the replies and skepticism.
You may be preventing me from making an Expensive Mistake. Looking for a Ktuner tuner...
Chugiak76
Mar 28, 2021 01:56 PM
Fluxmerc
Sep 22, 2012 02:40 AM
Lyon[Nightroad]
Nov 18, 2010 04:17 AM
Romulus
Sep 18, 2010 09:58 AM
KnifeEdge_2K1
43
Feb 15, 2007 12:28 AM
