Front control arm horizontal bolt bound
Old Jul 14, 2025 | 12:10 PM
ohfit2011's Avatar
After backing out about 3/8", my horizontal bolt on my control arm is bound, in both directions. I feel like it's going to sheer if I try to force it. It's not budging any amount. Not sure if you can see from the picture, but the bolt appears to be leaning down to the right just a tad. I tried a pry bar up top to see if I could pry the control arm top down to align it but it doesn't move. I tried jacking up the control arm just a bit and no use.
Old Jul 14, 2025 | 02:32 PM
GrE8_Fit's Avatar
Is the LCA attached to anything, still? Maybe you can relieve the tension somewhere else.
Old Jul 14, 2025 | 02:37 PM
ohfit2011's Avatar
Just the 4 bolts that attach it to the frame. Steering knuckle is already off (I'm replacing bearings, hub, LCA). I had the 3 other bolts off but I thought perhaps that was causing the bind, so I put them back on, but that didn't help.
Old Jul 14, 2025 | 02:58 PM
ohfit2011's Avatar
I got it… Another round of pb blaster and induction heater. It was just rust. I thought it got bound by tension.
Old Jul 14, 2025 | 04:32 PM
GrE8_Fit's Avatar
Wow what a battle. Glad it worked out.
Old Jul 15, 2025 | 12:41 PM
Mister Coffee's Avatar
Thanks for following up. I was going to recommend YouTuber Gearhead Bryan. He uses PB Blaster (or other solvent) and heat, too.
Good luck.
aaa12345
Mar 13, 2024 11:41 PM
ragingti
May 3, 2021 11:21 AM
ansys
Nov 19, 2017 03:22 AM
B-Nut
Jun 3, 2005 01:06 AM
TeGGer®
May 4, 2005 04:44 PM
