2010 honda fit windows won't roll down 😡
Old Jul 25, 2025 | 10:15 PM
Dbcreator11's Avatar
Hi guys I picked up my 3rd Honda fit and couple days ago since my daily has bad oil leak. The one I got the other day is a 2010 fit sport and the issue im having is the dam windows won't roll down! Only one that will roll down is the front passenger window. I figuerd it was something to do with the window switch but NOPE! I ended up swapping both the driver side doors out as the ones that was on the car had dents and a hole ripped in it so I swapped them with mine from my 09 fit which by the way the windows worked perfect in that fit. So that begin said I know for fact the motors are good. The window switch is good because all that came from my other car. I checked all the fuses and there fine. I don't know what the hell there is left that it could be! Only thing I didn't change was the passenger rear door or motor. I wouldn't think that would have any effect on the other windows though. They also won't roll down with the switches on the corresponding doors. Im all out of ideas! Anyone have any ideas?
Old Jul 27, 2025 | 05:49 AM
Limpy's Avatar
Can you check the continuity between fuses? Driver's side window won't go down either?
I don't see a single point of failure that would kill all doors but the passenger if the driver's isn't working. If the driver's is working, it could be a break in the wire after the relay depending on how that splice is done. Or it could be several wires damaged
https://www.hondafitjazz.com/manual/...bat00i008.html
Old Jul 27, 2025 | 06:32 PM
I got it it was a dam fuse. The continuity test failed me. Ether that or I missed that fuse cause I checked all. I used a light tester and tested the fuses again for the window and sure enough it was blown. Just glad that's all it was.
Old Sep 17, 2025 | 12:14 PM
AH64Armament's Avatar
This is one of the items I came here to investigate.
I have an issue with the left-rear door window not operating. It won't work from the Driver's control or the door's control. I hope it's just a fuse too.
Old Sep 24, 2025 | 10:43 AM
dondude32's Avatar
I had the same problem. Took fuse #19 out and it was good. Looked a little corroded so I sanded it, put it back in and window started working again.
Old Sep 24, 2025 | 12:05 PM
I replaced the fuse and it didn't resolve the issue. I suspect the motor in the door.
FitInParadise
Feb 17, 2024 04:09 PM
Surfingkidd3
Aug 17, 2020 10:45 AM
fariza
Nov 3, 2013 01:43 AM
ReeSpeed
Jul 13, 2010 08:54 AM
prim3tim3
Apr 24, 2010 05:48 PM
