View Poll Results: Are you experiencing high oil consumption?
yes very
20.00%
no
80.00%
a little
0%
Multiple Choice Poll. Voters: 5. You may not vote on this poll
Ge6 2013
Old Oct 23, 2025 | 05:37 AM
dankimkim's Avatar
Ge6 2013
Is there any issue with this series regarding High oil consumption?
And anyone facing this ,what's the remedy that has worked?
Old Oct 23, 2025 | 08:47 AM
Drew21's Avatar
I have a 2010 GE8 in the US with 128K miles. I have owned the car for 5 years (after my younger brother owned it for 8 years) and change the 0w-20 synthetic oil and filter once per year after 5000-ish (highway/long-trip) miles. My oil level does not change over the year.
How you fix oil loss depends on what is causing your oil loss. If you're burning oil you have to figure out how the oil is getting from where it's supposed to be to where it's not supposed to be - stuff like rings and valve guide seals - and remedy that problem. If you have a leak, you again have to figure out how the oil is getting from the inside of the engine to the outside and fix the seals that are leaking.
Old Oct 23, 2025 | 08:51 AM
PK86's Avatar
I have a 2012 and I drive it a lot..... The oil level does not drop any noticeable amount between oil changes.
Old Oct 23, 2025 | 08:54 AM
dankimkim's Avatar
Someone had commented that the specific model had been recalled due to burning oil & recommended changing engine to a slim engine.I am in Kenya and most Honda owners use 5w40 here
Old Oct 23, 2025 | 09:01 AM
Drew21's Avatar
I think most folks here are in the US/Canada. Which engine is in your Fit? Which "slim engine" are you talking about?
AnnieJ
Nov 17, 2023 05:11 PM
billinsf
Aug 4, 2023 10:48 PM
Eddy1234
Mar 27, 2017 08:52 PM
vec
Mar 24, 2014 08:35 AM
mitch24
Car Shows, Events, and Racing
Nov 5, 2013 03:44 AM
