2013 sport in need of a clutch
Old Jan 30, 2026 | 01:02 PM
2013fitowner's Avatar
I've had my 2013 fit sport for almost 4 years now and the clutch has started slipping. Looking for budget friendly replacement options just needing a clutch to get me by. it's just a daily driver so no performance clutch is needed but I've been wanting to upgrade and dont know what brands to trust. Thanks in advance to any advice given.
Old Jan 30, 2026 | 01:24 PM
mattsp999's Avatar
how do you know its the transmission? I might have a similar issue loss of power only at highway speeds replace coils,plugs maf sensor,throttle body reprogrammed and oil change still loosing acceleration only at highway speeds
Old Jan 30, 2026 | 01:29 PM
ik it's a clutch because the car is high mileage and it's been close to 100k mile since the last clutch was put in. it's not a loss of power the rpm climbs but speed doesn't go with it which is exactly what a slipping clutch will to on a manual vehicle and it currently only does it under heavy load but i dont want to be stranded and have to call a tow
as for your issue is you car manual or auto trans?
Old Jan 30, 2026 | 02:09 PM
mattsp999's Avatar
its automatic base 2009
Old Jan 30, 2026 | 02:11 PM
and at highway speeds it just won't accelerate like if you wanted to pass or it looses power and slows down on its own?
Old Jan 30, 2026 | 02:26 PM
mattsp999's Avatar
when driving on the highway the car will jerk/ buck and then the car will start to slow down while my foot is on the gas, and I see the rpms are up but no acceleration. I will eventually pull over, turn the car off and on and all the lights go away on the dash. The car will drive fine until it happens again.
Old Jan 30, 2026 | 02:33 PM
what lights come on?
Old Jan 30, 2026 | 03:53 PM
Mattsp's Avatar
Engine light would come on and when I turned off the car the light would go away
Old Jan 30, 2026 | 04:39 PM
id try and get it to do it then scan the codes with a code reader and that might help you narrow down your problem
Old Jan 30, 2026 | 08:19 PM
Mister Coffee's Avatar
I hate it when people on a forum answer a question with a question. Offer advice based on the data provided. Please.
Thank you.
Matt526l
Apr 21, 2025 06:42 AM
james13fit
Sep 17, 2023 12:53 AM
RubyQQ1211
Jun 24, 2021 05:53 AM
Aaronbodywork@gmail.com
Nov 21, 2019 07:31 AM
desertsp
Aug 20, 2016 06:06 PM
