Range select seal leaking...?
Old Feb 27, 2026 | 01:15 PM
hufflepuff's Avatar
Hello all,
i had what i THOUGHT was an oil leak from the range select sensor on the driver side of the transmission case. i replaced that, but i am still leaking a significant amount of fluid from the vicinity of the range sensor. I presume there is a seal behind the range / shift select sensor that can also leak? If so, could someone confirm whether it is this part number?
Oil Seal (9X18X7) (Arai) - Honda (91201-PA9-004)
https://www.hondaoempartsworld.com/parts/honda-oil-seal-9x18x7-arai-91201pa9004
How to access transmission range switch - Unofficial Honda FIT Forums
Old Apr 10, 2026 | 06:14 PM
hufflepuff's Avatar
UPDATE: This WAS what was leaking, and this WAS the correct seal. Had to use a screwdriver to get the seal out (was stuck in there pretty good, and a socket to drive in the new seal. but Voila, no more leaking!
Canadianmoose
Oct 16, 2023 01:14 AM
kinosh
Oct 31, 2022 07:40 AM
MarcoM
Mar 26, 2020 03:40 PM
1990hondahf
Oct 20, 2010 05:11 PM
contagiouss_blue
May 4, 2005 04:44 PM
