Auto Dimming Rear View Mirror
Old Oct 31, 2008 | 02:49 PM
zakurie's Avatar
Has anyone installed, or have links for, an auto-dimming rear view mirror?
Old Oct 31, 2008 | 03:12 PM
FitStir's Avatar
Check this thread ---> https://www.fitfreak.net/forums/2nd-...placement.html
I think I also read a different thread where the person used an Acura part also, but I cant find that thread.
Old Oct 31, 2008 | 05:21 PM
badself's Avatar
My other vehicle has an autodim rearview mirror. My '09 fit has autodim, also. It's called Formula One Pinnacle 35% tint on the rear glass.
Old Oct 31, 2008 | 06:30 PM
JDM_DOHC_SiR's Avatar
Old Oct 31, 2008 | 09:10 PM
spreadhead's Avatar
I have three of these (Fit, Forester, and Xterra), like them, recommend them. You can pick with or without compass, thermometer, and map lights. On a Fit you must glue a wedge to the windshield. Cipa DUAL-DISPLAY AUTO DIMMING MIRRORS : JC Whitney: Auto Parts & Accessories
Old Oct 31, 2008 | 09:12 PM
B1str0's Avatar
RubberBabyBuggyBumpers
rock 15% tint on the hatch and problem solved .. hids cannot blind meeee lol
Old Oct 31, 2008 | 10:10 PM
fitscott's Avatar
I was told that there is an adapter to connect the Gentronics mirror to the stock honda mirror base. I haven t ordered it yet, but I'm still waiting for my Fit. I have one on my MDX and don't think I could to back to flicking the mirror. Also I want the Homelink instead of the garage door openers.
Old Mar 23, 2009 | 09:08 AM
toxicavenger's Avatar
Does anyone now what kind of mount is on the 08'Sport? Is it a wedge? Thanks
Old May 13, 2009 | 07:15 PM
ziggy_fit's Avatar
what about the auto dim that comes on the civics or the insight? are these plug and play for the 09 fit? anyone know?
Old May 14, 2009 | 01:32 AM
niko3257's Avatar
FitFreak GE8 DIY Guy
there no way it can be plug and play cause there is no wires.
you have to splice it in yourself. most likely to the map lights.
Old May 14, 2009 | 04:19 PM
ziggy_fit's Avatar
i was talking about this
http://www.collegehillshonda.com/ins...ightmirror.pdf
i wonder if the wiring harness works with the fit?
Old Dec 11, 2011 | 09:15 AM
gattaca's Avatar
Having just done this, it depends on the model and what connectors you have at your fuse panel - but very likely yes. Check your fuse panel from those instructions prior to ordering.
The cabling routing will be very similar. I noticed many later Honda models have that 8 pin standard connector at the fuse panel which is often unused in the manuals and that connector seems to be designed for adding many accessories b/c that's where they connect in via a factory harnesses.
For these mirrors, that 8-ping plugs in w/ no problem. The rub is the 2nd connector in the harness depends on which mirror / harness / connector you need. I've seen 2 models, 1 for the CR-Z which has a 2nd connector as a 12 pin and the other for the Insight which has a 13 pin 2nd connector.
My 2010 Fit has the 13 pin 2nd connector.
That 2nd connection is so the mirror can get the +12 signal when the Auto is in reverse and "un-dim" the mirror automatically. You can plug in the 8 Pin w/o the 2nd connector but you get no backup un-dimming.
Bottom line, if you check your fuse panel for that 8-pin and verify that you have a 13-pin 2nd connector (see those instructions) then the "Insight Mirror" harness / kit should work. I cannot verify this 100% b/c I do not have the Insight Kit but from the instructions, it calls out the 13 pin connector.
Cheers.
Old Dec 11, 2011 | 09:48 AM
Jodele's Avatar
This is in my '07
I've mounted a similar on in an '11
Old Dec 11, 2011 | 10:59 AM
CrystalFiveMT's Avatar
I dislike the autodim mirrors. Doesn't work quickly or effectively. Plus, how difficult is it to raise your right hand to flick a simple lever?
Old Dec 11, 2011 | 01:14 PM
Krimson_Cardnal's Avatar
Here's what I installed: Amazon.com: Gentex GENK21A Auto Dimming Mirror W/compass Temperature: Automotive
It's a great OEM quality mirror and the auto dim works flawlessly plus you get outside air temp. Gentex actually supplies OEM mirrors to car mfg's.
Install is quite simple, hers a good guide: https://www.fitfreak.net/forums/fit-...-homelink.html
The 21A has a temp sensor that I mounted behind the front license plate. Trick was running that back inside the cabin. I came in along the inside of the right quarter panel, from inside the engine bay, to the drivers door jamb then in through the connections from the side view mirror. Fish a stiff wire from inside the engine bay towards the door and you find it's a clear path.
K_C_
Old Dec 12, 2011 | 08:53 AM
FitStir's Avatar
Yeah. I was thinking about either the Insight or the CR-Z auto-dimming options.
but then I thought of this
Although most people say it works just fine.
Still undecided if I want to get the Honda auto-dimming, or just keep doing it manually and getting the spoon mirror cover (great reviews).
Old Jan 19, 2012 | 08:21 PM
rcorbin's Avatar
Originally Posted by Jodele
This is in my '07
I have a 07 fit as well and looking for an aftermarket mirror. What mirror is this? Thanks...
Old Jan 20, 2012 | 01:36 PM
I would say it looks like the Gentex I posted here. It really is a first class mirror and no reason it wouldn't install on your Fit.
Old Jan 20, 2012 | 01:59 PM
Jodele's Avatar
This one is the closest one to mine. Mine also has map light that are no longer offered.
Old Jan 21, 2012 | 12:48 AM
rcorbin's Avatar
Auto-dimming mirror
Thanks, I'll give it a try. Honda dealer wants $130 to install so I may do it myself...
