where's the aftermarket parts if any for 09
Old Nov 5, 2008 | 10:58 PM
samson simpson's Avatar
Thumbs up where's the aftermarket parts if any for 09
i just bought a white 09 and ive got to make it FIT me
Old Nov 6, 2008 | 12:02 AM
IS300na-t's Avatar
Tanabe is going out with springs right now and for parts you have to get them from Japan for now since nothing in the US really yet till probably next year.
Old Nov 6, 2008 | 03:56 AM
mole177's Avatar
plenty of stickers out there...sky's the limit.
Old Nov 6, 2008 | 05:29 AM
kingofpicklez's Avatar
lol stickers.. check those off the list.
can't wait for intake and exhaust to be available in the United States, not just Japan
Old Nov 6, 2008 | 11:19 AM
xJGBx JayNutz's Avatar
the only bad part of a brand new car no new parts !!!! i had the same problem when ford switched to the duratech in the 05 focus
Old Nov 6, 2008 | 11:44 AM
manxman's Avatar
PRM is working now on their "Jet Stream" intake for the '09s. The air intake on the '09 is completely different from the 1st. Gen Fits. Now there is no fender well opening for cold air- . The older Fits are a lot friendlier for all kinds of after-market intakes than the new ones. Without relocating the battery, you can forget chambers. The GE does have an odd "semi-ram air" duct made of soft plastic fastened to the underside of the hood. But all it does is carry air from the leading edge of the hood into the rear driver side quadrant of the engine bay. The stock air inlet is a big rubber doughnut, like a coupling on a shop vac,that just sits directly under the brake master cylinder, against the firewall.
Gerry has my advance order for the first '09 PRM intake. I am sure that the PRM will make better use of the stock ram air tunnel.
It will be a wait for '09 Fit exhausts too. The '09 is not a straight through design- the inlet and outlet tubes are both in the front wall of the muffler. Outlet makes a 180 degree turn and wraps around the right side of the muffler before heading under the rear bumper.
Progress Technology is working on an add-on rear sway bar to add stiffness to the stock rear bar. Member saveacivic's '09 Fit is the test bed for the new bar, and he may have some info. for us around 11/15.
Old Nov 6, 2008 | 04:29 PM
AZEqualizer's Avatar
One thing I found out was the shifter is the same so last years short shifter kits work.
2009fit
Mar 6, 2011 05:15 PM
misfit09
Feb 21, 2011 09:38 AM
SumYunGai
Apr 20, 2009 07:48 PM
AztecDude
Apr 9, 2009 11:21 AM
Tetsugen
King Motorsports
Sep 16, 2008 03:17 PM
