Any problem with 205/50-16's on Stock Sport 16" Alloys?
Old Nov 20, 2008 | 12:44 PM
pbanders's Avatar
Just found a great deal on Goodyear Eagle F1 GS-D3's from Tirerack ($56 each on closeout, plus a $50 discount!) in 205/50-16's (only 0.75 mm shorter than the 185/55's).
Anyone gone to 205/50-16's on the stock 16" Sport alloys? I can't imagine there would be any problem with clearances, or the pressure sensors, etc., but it's worth asking before I complete my order. TIA.
UPDATE: Cost from Tirerack for this deal is $224 + $44 shipping -$50 rebate = $218 delivered.
Old Nov 20, 2008 | 12:54 PM
CrystalFiveMT's Avatar
I was considering the same size. Tnkgrl was also considering that size but went with 195/50/16 on the stock wheels. I can't find her post that stated why she went with that size. Her 07 had 205/45/16 on HFP wheels.
Old Nov 20, 2008 | 01:05 PM
FitStir's Avatar
Question Good Question OP.
Anyone know what's the diameter difference between those and stock?-----edit..
Just saw the edit op, and .75mm??? That's not much of a difference.
Any pro's/cons with the new tire size?
Old Nov 20, 2008 | 01:22 PM
No, 0.7 mm is essentially the same sidewall height. Different tire brands/models of the same size can differ much more than that. Then add in your normal tire wear which reduces height as well. Obviously the 205/50 size won't show ANY difference to the eye. But the 205 size is 2 sizes wider. Tnkgrl said that the 09 Fits have less wheel well gap, which is one of the reasons she went with 195/50. The 205/50 may rub when you turn the front wheels.
We need clarification from her or someone else who's upsized.
Old Nov 20, 2008 | 10:19 PM
BobbyK's Avatar
Old Nov 21, 2008 | 11:50 AM
zakurie's Avatar
bump to the top...I wanna know if there will be rubbing issues.
Old Nov 21, 2008 | 12:01 PM
pbanders's Avatar
Thanks! I've been holding off on my tire order, waiting to hear!
Old Nov 22, 2008 | 05:44 PM
pbanders's Avatar
FWIW, I went ahead and ordered the 205/50-16's, it was just too good a deal to pass up. From what I could see, the Fit has gobs of clearance and should be able to handle a tire that's fatter by 1.0 cm on the inside and the outside. I'm going to store these tires until I need them, so I'm hoping to see some info by the time I'm ready from someone else who has tried it out.
Old Nov 22, 2008 | 07:49 PM
BakedCookies's Avatar
you'll be fine. They will look great.
Old Nov 24, 2008 | 11:25 PM
mayorwirth's Avatar
THANKS FOR KEEPING CLOSE EYE AT TIRERACK. WILL HAVE 205/50/16 INSTALLED TOMORROW, 25th. WILL LET YOU KNOW HOW THEY FIT.
Old Nov 24, 2008 | 11:29 PM
bryanfor311's Avatar
are you simply installing the wider tires for look or are you unhappy with the factory tires?
Old Nov 25, 2008 | 02:10 AM
animes2k's Avatar
I had those tires in 17 on the Subaru's summer rims. LOVED them.
Old Nov 25, 2008 | 08:14 AM
mahout's Avatar
The difference between 205/50x16 and 185/55x16 tires diameter is .060", or about 1.5 mm. 24.07" vs 24.01". The tread corner will be 10 mm (3/8") closer to the fender arch but on the 09 we see here that fits without interference. You can measure that with a ruler. The .75 mm number is half the diameter difference which means the Fit rides .75 mm, or 1/32" higher than stock . Never see it.
On the stock 16x6/53 rims they should fit OK.
Just to be clear, this applies to 09, not 08 and prior Fits !
Old Nov 25, 2008 | 10:19 AM
FitStir's Avatar
Tha'ts a detailed and clear explanation... +reps.
So would you recommend the wider tires for better grip?
and I'm guessing mpg's might go down slightly?
Thanks for the info.
Old Nov 25, 2008 | 10:26 AM
pbanders's Avatar
BTW, when I looked yesterday, they've dropped the price from $56 to $49 a tire! With the additional $50 rebate, it's an even better deal. But, there's a catch - on my receipt in email, I see that these tires are listed as "2004 production" - they're four years old. IMO, that's the limit of how old a tire should be considered to be "fresh'. As a result, I'm going to put my on immediately and store my OEM set. Others out there may want newer production tires, 2 years or less. Caveat emptor.
Old Nov 25, 2008 | 12:20 PM
animes2k....nice avatar pic!
Old Nov 25, 2008 | 04:46 PM
mahout's Avatar
The wider tires will have better dry grip but less on ice, snow, or heavy rain. Being heavier at the circumference they will be likely to lower your mpg at least slightly.
Old Nov 26, 2008 | 01:05 PM
pbanders's Avatar
FYI, the tires arrived yesterday. As soon as I find a place to mount and balance them, I'll post some pics showing the clearances. I agree with mahout, better dry grip, but these particular tires have superior wet grip, too. Ice and snow? Forget it! And yes, they will lower the mileage, as they're heavier (acceleration losses) and wider (more wind resistance). I'm also hoping the wider, more sticky tires will help reduce stopping distances, something the Fit needs help with.
Old Nov 26, 2008 | 01:13 PM
animes2k's Avatar
I agree. I was REALLY surprised how well the tires did in the wet. But definitely swap those out when the temps drop below 45F
I'd totally get a set if I had a second set of rims or steelies for the stock/winter tires.
Old Nov 26, 2008 | 01:19 PM
pbanders's Avatar
animes2K, FWIW, you might want to get them and hang on to them, anyway. They've dropped the price to $49 each, plus a $50 rebate on purchase of 4. Shipping by UPS to my house was $44, so after rebate, the total cost is only $190, hard to pass up!
