Disabling automatic AC on defrost
Old Dec 9, 2008 | 12:21 AM
Virtual's Avatar
Originally Posted by umop-apisdn
Silly me, I thought the fact that the light on the AC switch turning off meant that the procedure worked. The compressor still cycles regardless whether the switch is on or not.
Exactly. You're not the first to fooled.
Old Dec 9, 2008 | 02:46 PM
secondspassed's Avatar
I know an even easier way.
1. Turn key to "on" (position before crank).
2. Move fan knob to "off".
3. Temp knob full blue (all the way to the left).
4. Position knob full left (arrow pointing to face only.
5. Turn key off.
6. Press the AC button and hold it down.
7. Turn key back to the "on" position and wait for 7 seconds while still holding the AC button down.
8. Release AC button and start the car.
Voila, now the AC doesn't come on automatically in defrost mode! You can however, turn it on if you're so inclined.
Anyone know if this method works on '07-08s?
Old Dec 10, 2008 | 12:19 AM
polaski's Avatar
07-08 Fits ac defrost isn't controlled by computer, so no. Try this
Old Dec 10, 2008 | 12:37 AM
niko3257's Avatar
FitFreak GE8 DIY Guy
great find. i will be doing this soon.
+rep.
Old Dec 12, 2008 | 09:28 PM
niko3257's Avatar
just did it today and it does work.
thanks again.
Old Dec 13, 2008 | 10:12 AM
Nabisco's Avatar
Senior Member
Well. this IS exactly what is going on. I thought I was going crazy.
When I have the defrost on, it uses the damn AC.
I tried the ignition/button trick and it didn't work for me. I'm going by the dealer today to get some wiper blades I'll ask them about it then.
Old Dec 13, 2008 | 11:45 AM
Virtual's Avatar
Geez! Why do you need to ask the dealer anything? Read this thread. It answers your question exactly.
Old Dec 14, 2008 | 01:49 PM
z06dustin's Avatar
+rep*10 ^15 haha.
awesome mod. it was a b*tch getting that low to see the connector, but i'm a big guy. works perfect thus far.
it's always pissed me off that the auto manfacturers do this, i can see having it come on automatically if you turn to defrost, but why not give us the choice to disable it by pressing the a/c button off?
Old Dec 14, 2008 | 03:28 PM
badself's Avatar
Have any of you folks beem able to reconnect this thing, being that the entire assembly doesn't pop out (as in the GD).
I'd like to disconnect also, but if it requires heroic measures to reconnect (anything more than a long pair of needle-nosed pliers), I might just pass.
Most of the time having the compressor run helps to keep my windows clear in cold and precipitation, but sometimes it's just plain unnecessary.
Old Dec 14, 2008 | 07:01 PM
z06dustin's Avatar
i think it would be pretty difficult to get re-attached, like stated before a very thin pair of needle nose might be your best bet... it might be easier to take off that part of the dash to do so.
Old Dec 14, 2008 | 07:20 PM
Virtual's Avatar
If you really need to re-attach it, you can. I see no reason to do that because you can always just click the AC button.
Old Dec 14, 2008 | 11:21 PM
  #32
xdream's Avatar
Re-attach wires
I believe you can remove the Radio and your wires should be visible. Removing the Radio on the GE8 is very easy, there is one screw from the bottom by the Air Recirculation slider.
Old Dec 24, 2008 | 01:25 AM
  #33
GUESTO's Avatar
One of the best mods! My car heats up quicker than before now. Thanks!
Edit: I meant the interior not engine, lol.
Old Jan 12, 2009 | 03:55 PM
  #34
willmax11's Avatar
Prototype
If you want to see a diff. method here is my post on a deflector that works great.
https://www.fitfreak.net/forums/cana...defroster.html
Old Jan 15, 2009 | 05:53 PM
  #35
freeurmind69's Avatar
Originally Posted by Roger's Fit
Ok. There have been some interest in disabling the automatic and forced use of AC while in defrost. I have done this, without cutting any wires, and you can still press the AC button to turn on the AC while in defrost.
Remove the small plastic panel below the heater knob. Use a screwdriver to carefully pry the lower portion off.
I could not get a picture up on the switch, but look in the slot closest to the steering wheel. You are looking for a plug in the back side of the switch, that has 2 wires. slide the connector off with a screwdriver. That's it! The plug has been pulled out of the slot to give you a view of what you are working with.
would it be possible to be more clear as to which part of the panel to "pull" from??? i've attemp to try this but the panel is in there solid!!
dont want to break the panel..
could someone explain the exact precedure? ie. "start from the part nearest to the power socket or from above??"
plus i see screw holes in the pic!!! does that have anything to do with it?? thanks..
Old Jan 16, 2009 | 09:08 AM
  #36
niko3257's Avatar
^^^^^ pull on it from the bottom. it's very though trust me.
i did it and while doing it i put a scratch on it.
pull out from the bottom and it should come out
with some brute force.
Old Jan 16, 2009 | 09:23 AM
  #37
Virtual's Avatar
I used the right end of this tool to pry the cover from the back edge:
Then the left end worked perfectly to unplug the connector.
Old Jan 16, 2009 | 12:00 PM
  #38
thanks!!
got it done finally.. and yes.. it was tough... thought i was going to break that piece in half..
thanks alot guys!~! much appreciated!!
Old Feb 9, 2009 | 11:20 PM
  #39
OneStopCustoms's Avatar
interesting, this won't work on my 07 though
Old Apr 18, 2009 | 12:05 PM
  #40
Eugene.Atget's Avatar
Just did mine. Work from the passenger side (North American). A tool like the one Virtual used would be perfect, but anything rigid enough and with an elbow in it will do to easily remove the panel. I used a tiny hex key, and worked from the bottom of the panel. Had it off in seconds with almost no force. The switch is on the driver's side, but find it by looking from the passenger's side. The connector on the back of the switch is rather large--maybe a bit more than an inch long--white, and has two wires coming from it. Just take a smallish screwdriver and gently pry it away from the back of the switch and you're done. Many thanks to Roger's Fit (Btw, how on earth did you know to do this? Or should I not ask.)
