Honda Fit 2009 GE8: How to Install JDM Emblems
Old Sep 9, 2009 | 10:40 AM
  #41
Committobefit08's Avatar
Just to add my two cents here. An easy way to remove the rear emblem without damaging it is like I said in another thread... just take a putty knife wrap it with a paper towel (so you don't scuff up the black on the hatch) slide the putty knife behind the emblem until its touching the stud. Then take a rubber mallet and tap on the stud and it breaks right off (just plastic). Then just pull the emblem right off. This way you don't damage the emblem and don't damage the door. If you ever want to reuse the stock emblem just glue back on or use emblem double sided tape to reapply.
Old Sep 9, 2009 | 07:07 PM
  #42
I like being Fit's Avatar
i like the back better than the front
Old Oct 20, 2009 | 12:51 PM
  #43
sg_yop's Avatar
The H red emblem does not sit flat on the rear garnish of our Ge Fit.
You will notice a slight curve surface o nthe rear.
Can someone advise me how to fix the rear emblem
Old Oct 20, 2009 | 05:11 PM
  #44
dnamsterr's Avatar
pfl for when i need to do this
Old Nov 7, 2009 | 01:53 AM
  #45
90 DGRZ's Avatar
it says that once you lay it down, the emblem will contour to the bend...but when i did mine today, i put a thin layer of 3m industrial double side tape on the bottom 1/4 to compensate so the emblem isn't under so much tension when bent into that position.
Old Jan 15, 2010 | 11:16 PM
  #46
Btrthnezr3's Avatar
Saweet...now that the weatherman says the temperatures will be above 64 for the next week or so, I'll be doing this mod. Thanks!
Old Jan 18, 2010 | 01:23 PM
  #47
Btrthnezr3's Avatar
Ok guys...I got out to test and install my emblems.
Front went fine...
Rear, I noticed was a little smaller--so I checked the part number
mine was 75701-S6M-Z01
I called icbmotorsport (where I purchased from) and he said he's been shipping tons out for the GE with that part number with no problems.
Has anyone else used that part number instead of the other number that the OP posted?
He is being very nice and I am returning the rear emblem for the correct number...Rear Type-R badge - 75700-S5T-E01
Old Jan 25, 2010 | 07:01 PM
  #48
Btrthnezr3's Avatar
Got my new emblem from icbmotorsport.com / jdmland.com and they were true to their promise in making it right with me--they now are going to start sending the part number 75700-S5T-E01 for the GE8 Fits.
Yay for those guys.
Old Jan 26, 2010 | 07:04 AM
  #49
moritz629's Avatar
hey i was looking to buy a set for my 09 jazz (australia), where can i get them from? i cant seem to find any of the right serial number off ebay =(
Old May 5, 2010 | 04:21 PM
  #50
ivtechFit's Avatar
anyone know where i can get RS emblem? just got my red H emblem today from jdmland.com
Old May 22, 2010 | 03:13 PM
  #51
sooznd's Avatar
removing " Fit" rear emblem
Does this apply to the Fit emblem? I want to remove my 2010 "FIT" emblem and replace it with the blue dot emblem from the GD model.
Thanks!
Old May 22, 2010 | 03:27 PM
  #52
thefit09's Avatar
Thanks!
That method should work. An even safer way, IMO, is to use dental floss and slowly work it behind the emblem. If you want to speed the process up, use a hair dryer to loosen the adhesive.
Old May 22, 2010 | 03:28 PM
  #53
thefit09's Avatar
ebay has a whole bunch
Old May 22, 2010 | 03:32 PM
  #54
sooznd's Avatar
Thanks!!
I have removed stickers on my Yamaha Vino with a hairdryer and it worked like a charm. The dental floss method sounds like a great idea for removing the emblem.
Will the adhesive on the back of the blue dot emblem be sufficient to stick to the car or do I need to add more adhesive?
I am also adding a Jazz emblem on the right side.
Old May 22, 2010 | 03:40 PM
  #55
thefit09's Avatar
Thanks!!
I replaced my emblem with the red dot emblem, and the adhesive on the back was sufficient enough for the job. Just make sure you get all of the "old" adhesive off from your current emblem before you put the new one on.
Old Sep 9, 2010 | 01:39 AM
  #56
blassty's Avatar
just wanted to pay some respect for this thread, it helped me get enough confidence to paint my emblems.
Old Nov 14, 2010 | 06:35 PM
  #57
Bernard's Avatar
Unable to take off the original emblem?
Originally Posted by kimonostereo
t
You'll want to take your pliers/clippers and clip off the ends of the emblem. Just feel around and take your time. I made sure to line the edge of the clippers up to the base of the grommet, then clip the ends. Then you just gently pry the emblem towards you and it should break free. You may hear the sound of the grommets falling off as well. Find them if you can and put them aside with the emblem.[/IMG]
I was even able to remove the whole front grill so i can easily can see the wo grommets. Are you sure I just need to use a clipper to break off the tip that lock the original emblem? I am so afraid to break it. But if you say just break it purposely in order to get that thing out, i will try it again. Can you confirm please?
Old Nov 14, 2010 | 06:51 PM
  #58
ThEvil0nE's Avatar
Here's an important tip for the rear red H badge...
pre-bend the badge, do the bending gradually until you get the exact contour of the rear emblem garnish surface... do this and your H badge will sit nicely and flushed.
also... heat gun or hair dryer would help alot on bending
Old Dec 30, 2010 | 01:24 PM
  #59
cfran55's Avatar
my rear fits terribly i pressed down harder on the top now the bottom right corner seems to pop out a little. i held it down for 5 minutes straight and gave up.
and i broke both oem H in half! dang
Old May 1, 2011 | 12:11 PM
  #60
thaijazzy's Avatar
hi sg-yop.im ben from switzerland,now live in chiang mai thailand.i had the same problem then i used one from the 1.gen jazz.it fits perfect. good luck
