Well... finished speaker installs: no pictures too frustrated
rockin 4 infinity kappa 6.5's
2 sore ass cheeks, 2 sore hands 2 sensitive fingers 2 sensitive thumbs 1 swollen knuckle 2 broken plastic tabs 1 broken cover plate AND 8 hrs later I finished R&R'ing speakers. this has been one of the more annoying car mods i've done in my life so far. just call/pm for number me if you need directions... knuckle hurts too much to type anymore. |
but was it worth it? Im sure they sound way better than the stocks. :D Im looking at installing some Rainbow 6.5's components in the front and rear doors.
so much clarity brah. but not enough bass! it's so much louder though.
one quick question: did the speakers come close to hitting the windows when you roll it down? I think my speakers are a little deeper than the Infinitys you installed. Im just hoping that mine clear.
the fronts are super close... i had to use a bracket that the speakers come with...
as for the rear, no bracket is needed. |
Mole,
It wouldn't have mattered as far as the difficulty of the install (many props for undertaking it :D), but for the sake of clearances, did you use the _shallow_ version of the Infinity Kappa's? Denoted by an "s" at the end of the model number. The model which I reckon is ideal for the GE Fit is the Infinity Kappa "62.9is", a shallow-mounting depth version of the Kappa 62.9i. It's very frustrating that Crutchfield doesn't stock (or even list) this version of the Kappa drivers, while you can see it on Infinity's website and order it from other vendors (I used HookedOnTronics). Also, for anyone planning to install speakers or pop Fit panels in general... you need this trim (clips, etc.) tool kit. It's actually listed in all of Honda's manuals and service docs with an actual Honda part#, but it's made by KTC and sold in many different places. Panel Popper Kit Hope that info helps! I've explored speaker installation in the GE8 quite a bit, but I haven't figured out what to do to get back the level of bass the cheapie paper cone drivers are still good at producing (even if not the most accurate bass). Cheers, Baz |
pics or it never happened
What door parts did you break and what door were they on..?
i did both of my fronts in about 30 mins. but i do that every day so its kind of second nature and it always helps to have all the right tools
after reading about mole177's adventure, I decided to have a professional install my components. The new speakers made a huge difference in my opinion. I had some Rainbow 6.5 components installed in the front and rear locations, and the clarity is amazing. Best upgrade yet!
ya RAINBOW's are amazing speakers. you pay a little more but its worth it. i have HERTZ energy's now and the sound is great.
I am planning to do the front and rear speakers myself. I got the instruction removing the rear door panel. Is removing the front door panel procedure identical?
Originally Posted by mole177
(Post 598418)
3 Attachment(s)
Originally Posted by Alpha Zero
(Post 602669)
The mids are in the stock location in the doors. dash tweeter Attachment 66556 Attachment 66557 Attachment 66558 |
Originally Posted by JDM_DOHC_SiR
(Post 602787)
its the clip that allows you to take the window thingy down. the part that is under the window toggle. and the other part was ELECTRICALLY taped back in place. the triangular plastic piece right above the window sill towards the back of the door. (you'll know if you see it.) |
Originally Posted by GE8
(Post 602971)
Originally Posted by aenokea
(Post 607210)
Here are some pics of my installation. My installer suggested that he install the tweeter for the rear speakers in the upper area behind the passenger window. He called it the sail panel. He experimented with different locations and said this gave the best sound. Different tweeters will sound different so it may not be the best location for other brands. He also painted them so they would blend into the sail panel.
The mids are in the stock location in the doors. dash tweeter http://i85.photobucket.com/albums/k6...6/IMG_0164.jpg |
Originally Posted by reako
(Post 607232)
Looks awesome man! Did you happen to notice exactly how the installer removed the stock front tweeters? Some members have inquired about this in the past. If it's easy enough I'll drop my A/D/S component tweeters in there until I get time replace the doors.
(Post 607237)
Its actually very simple. If you look at the tweeter from outside the car, youll notice a very small opening where you can place a small flathead screwdriver and pry it off. Make sure you cover the scredriver with tape or something so you dont damage the dash or tweeter pod.
(Post 603022)
(Post 607246)
Aren't Rainbow's like the Maserati of speakers? Very exclusive gear there...nice work!
